De Longhi Heater temperature Sensor
Views: 6.6K
View statistics:
Past 24 Hours:
6
Past 7 Days:
33
Past 30 Days:
119
All Time:
6,640
Comments: 2
2 comments on steps.
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 40 minutes
Difficulty: Easy
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Community-Contributed Guide
Introduction
Go to step 1 ↓
If your heater has a temperature sensor failure alarm proceed with component replacement or repair when possible.
ELECTRONIC BOARD WITH PROBE FOR DE LONGHI FAN HEATER TCH7091ER TCH7092ER
Replacement part available at eBay
    1. De Longhi Heater temperature Sensor, Temperature Sensor: step 1, image 1 of 1
      • Heater unit bricked with PF error (fault temperature sensor)
      Ask FixBot
    2. De Longhi Heater temperature Sensor: step 2, image 1 of 1
      • Remove the four Phillips screws with a Phillips screwdriver
      • Remove the remaining 2 screws with a Torx screwdriver
      • Remove the cover
      Ask FixBot
    3. De Longhi Heater temperature Sensor: step 3, image 1 of 1
      • Open the clamps by unhooking them with pliers or using a flathead screwdriver.
      Ask FixBot
    4. De Longhi Heater temperature Sensor: step 4, image 1 of 1
      • Unscrew the Phillips screw to remove the temperature sensor.
      Ask FixBot
    5. De Longhi Heater temperature Sensor: step 5, image 1 of 1
      • Unclip the temperature sensor connector from the motherboard.
      Ask FixBot
    6. De Longhi Heater temperature Sensor: step 6, image 1 of 1
      • The temperature sensor had broken because it was corroded by moisture.
      Ask FixBot
    7. De Longhi Heater temperature Sensor: step 7, image 1 of 2 De Longhi Heater temperature Sensor: step 7, image 2 of 2
      • With a soldering iron I proceeded to weld the broken part and to connect the 2 tracks by applying electric wire and some tin.
      • If the component can not be repaired, you can find the complete electronic board replacement on eBay
      Ask FixBot
4 other people completed this guide.
Special thanks to these translators:
it en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Smilzo
12,380 Reputation
39 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 33
Past 30 Days: 119
All Time: 6,640
