De'Longhi EC155 Water Valve Replacement
    1. De'Longhi EC155 Water Valve Replacement, Water Reservoir: step 1, image 1 of 2 De'Longhi EC155 Water Valve Replacement, Water Reservoir: step 1, image 2 of 2
      • Flip open the top panel to reveal water reservoir.
      • Grab the water reservoir by the handle and lift out.
      Ask FixBot
    1. De'Longhi EC155 Water Valve Replacement, Bottom Panel: step 2, image 1 of 2 De'Longhi EC155 Water Valve Replacement, Bottom Panel: step 2, image 2 of 2
      • Flip the device on its head.
      • Using the Phillips #2 screwdriver, unscrew the four 12 mm screws found at each corner of the bottom panel.
      • Lift the panel off or flip the device over and let the panel drop out.
      Ask FixBot
    1. De'Longhi EC155 Water Valve Replacement, Top Panel: step 3, image 1 of 1
      • Before flipping the device, removed the black container and grill.
      • Flip the device on its head, front end facing you.
      • Using the Phillips #2 unscrew the two 52 mm screws found underneath the top portion of the device.
      Ask FixBot
    2. De'Longhi EC155 Water Valve Replacement: step 4, image 1 of 1
      • Flip the device back to its proper orientation.
      • Using the Phillips #2 screwdriver remove the two 52 mm screws found on the lip next to the reservoir.
      Ask FixBot
    3. De'Longhi EC155 Water Valve Replacement: step 5, image 1 of 2 De'Longhi EC155 Water Valve Replacement: step 5, image 2 of 2
      • Insert the two plastic opening tools beneath the top knob.
      • Use the two plastic opening tools as leverage to lift the top knob off.
      Ask FixBot
    4. De'Longhi EC155 Water Valve Replacement: step 6, image 1 of 1
      • Grasp the lid firmly with both hands.
      • Pull mightily with both hands away from the device.
      • If you hear a slight snapping sound, it is supposed to do that.
      Ask FixBot
    5. De'Longhi EC155 Water Valve Replacement: step 7, image 1 of 2 De'Longhi EC155 Water Valve Replacement: step 7, image 2 of 2
      • Use a plastic opening tool to push in the slot on the back panel while lifting.
      • Similarly, reach into where the reservoir used to be and insert a plastic spudger underneath the inside panel.
      • We recommend to not use your fingers for this step because there is a chance they will be pinched.
      Ask FixBot
    6. De'Longhi EC155 Water Valve Replacement: step 8, image 1 of 2 De'Longhi EC155 Water Valve Replacement: step 8, image 2 of 2
      • You are now ready to lift the top off.
      • Place one hand near the back, the other at the front, and lift.
      • You may want to lift the front and back individually by pulling one a little off the part before the other. Afterwards, lifting the top off entirely will be easier.
      Ask FixBot
    1. De'Longhi EC155 Water Valve Replacement, Water Valve: step 9, image 1 of 2 De'Longhi EC155 Water Valve Replacement, Water Valve: step 9, image 2 of 2
      • Flip the device and remove one end of the tube from the water reservoir hole.
      Ask FixBot
    2. De'Longhi EC155 Water Valve Replacement: step 10, image 1 of 2 De'Longhi EC155 Water Valve Replacement: step 10, image 2 of 2
      • Pull the tube through the chamber with the water pump so it comes out of the top end.
      • Twist the valve counterclockwise while pulling gently.
      Ask FixBot
6 other people completed this guide.
David Griffith
1,492 Reputation
9 Guides authored
Cal Poly, Team 4-2, Maness Fall 2015 Member of Cal Poly, Team 4-2, Maness Fall 2015
CPSU-MANESS-F15S4G2
4 Members
45 Guides authored
5 Guide Comments
I done this earlier today without the guide after it started to leak after descaling the machine , so i fixed it by taking valve apart an putting back together it worked once before leaking again , im just concerned it will just go again if i replace the safety valve , im wondering if scale has moved an is blocking and causing valve to leak? any ideas?
Russell L - Reply Share
Great description! Is the water valve ever used to control brew pressure?
Thatcher Drake - Reply Share
Great guide!, carefull the water valve has inside, two small orings, don´t loss it. Muy buena guia, hice todo lo indicado y funciono perfectamente, mi máquina comenzo a gotear agua por dentro y gracias a este manual pude encontrar la falla, que es la válvula, tengo con la maquina mas de 7 años y hasta ahora fallo, la válvula por ser de plastico no se puede reparar, pero se consiguen las partes en ereplacementparts.com. Solo un comentario la valvula tiene 2 orings pequeños, así que tengan cuidado cuando la saquen no se les pierdan.
Nelson Troyano - Reply Share
I update my comment, the spare part for the valve has arrived (ereplacementparts.com), I replaced it and everything is perfect, I can drink my espresso again.
Actualizo mi comentario, ya me llego el repuesto de la válvula (ereplacementparts.com), lo reemplace y todo perfecto, de nuevo puedo tomar mi expresso.
Gracias Nelson por el buen consejo!
Omar - Reply Share
Past 24 Hours: 3
Past 7 Days: 10
Past 30 Days: 59
All Time: 7,013
