De' Longhi CTOV 2103- AZ
    1. De' Longhi CTOV 2103- AZ, Pull the lever: step 1, image 1 of 3 De' Longhi CTOV 2103- AZ, Pull the lever: step 1, image 2 of 3 De' Longhi CTOV 2103- AZ, Pull the lever: step 1, image 3 of 3
      • First unplug the cable. ...Pull off the lever, it is snapped in.
      • Pull out the drawer.
      • Now clean it with a vacuum.
      • On the underside are 4 screws Torx 10 resistant visible - in each corner one.
      Ask FixBot
    2. De' Longhi CTOV 2103- AZ, Screw: step 2, image 1 of 2 De' Longhi CTOV 2103- AZ, Screw: step 2, image 2 of 2
      • Detail of the screw
      Ask FixBot
    3. De' Longhi CTOV 2103- AZ, Housing chrome plastic ring: step 3, image 1 of 3 De' Longhi CTOV 2103- AZ, Housing chrome plastic ring: step 3, image 2 of 3 De' Longhi CTOV 2103- AZ, Housing chrome plastic ring: step 3, image 3 of 3
      • here you have two pictures of the housing and the chrome plastic frame.
      Ask FixBot
    4. De' Longhi CTOV 2103- AZ, Lever: step 4, image 1 of 2 De' Longhi CTOV 2103- AZ, Lever: step 4, image 2 of 2
      • Here you have details of the lever and how it is snapped in the mechanic.
      • This shows you how to unlock it when you dismantle the housing. Good luck. ;)
      Ask FixBot
    5. De' Longhi CTOV 2103- AZ, Tempeaturesensor: step 5, image 1 of 2 De' Longhi CTOV 2103- AZ, Tempeaturesensor: step 5, image 2 of 2
      • Detail of the Sensor: It is the little black pearl at the black hoses which is strapped to the white hose.
      Ask FixBot
    6. De' Longhi CTOV 2103- AZ: step 6, image 1 of 3 De' Longhi CTOV 2103- AZ: step 6, image 2 of 3 De' Longhi CTOV 2103- AZ: step 6, image 3 of 3
      • The connector from the main platine to the switch platine.
      Ask FixBot
    7. De' Longhi CTOV 2103- AZ: step 7, image 1 of 3 De' Longhi CTOV 2103- AZ: step 7, image 2 of 3 De' Longhi CTOV 2103- AZ: step 7, image 3 of 3
      • Details of the plug and the bottom part after disassembly.
      • Where to find the plug for the yellow ground wire i show you in the next step. :)
      Ask FixBot
    8. De' Longhi CTOV 2103- AZ: step 8, image 1 of 2 De' Longhi CTOV 2103- AZ: step 8, image 2 of 2
      • here you can see where the yellow cable belongs to.
      Ask FixBot
    9. De' Longhi CTOV 2103- AZ, Reassembly: step 9, image 1 of 3 De' Longhi CTOV 2103- AZ, Reassembly: step 9, image 2 of 3 De' Longhi CTOV 2103- AZ, Reassembly: step 9, image 3 of 3
      • Reassembly: Putt all cables at the right places, don't forget the yellow cable at the housing !!!
      • Look at the picture how to fit in the metal notch in the right place !
      Ask FixBot
    10. De' Longhi CTOV 2103- AZ: step 10, image 1 of 3 De' Longhi CTOV 2103- AZ: step 10, image 2 of 3 De' Longhi CTOV 2103- AZ: step 10, image 3 of 3
      • Here the notch is in the right place.
      • Do NOT forget to make an insulation test. Check the wiring with a multimeter.
      • Made in China.
      • Hope it was fun and may the pictures help you. Greets. :)
      Ask FixBot
3 other people completed this guide.
Schwarzstein
2,972 Reputation
13 Guides authored
3 Guide Comments
The lever broke on my toaster. And it's difficult to glue it.
skan - Reply Share
My daughter toasted a piece of bread but the bread burned and caught fire. I've opened the toaster, and see no fire-damage. Although, it is impossible to toast because the lever won't stay down.
Dieter Troubleyn - Reply Share
I referred to this post to replace the horribly short code in CTOV2003.
Thanks to your detailed explanation, I was able to complete the replacement in one go without any trial and error.
Thank you very much.
amurobs - Reply Share
Past 24 Hours: 4
Past 7 Days: 30
Past 30 Days: 106
All Time: 3,747
