Daymak Max S Kickstand Replacement
    1. Daymak Max S Kickstand Replacement, Kickstand Replacing: step 1, image 1 of 3 Daymak Max S Kickstand Replacement, Kickstand Replacing: step 1, image 2 of 3 Daymak Max S Kickstand Replacement, Kickstand Replacing: step 1, image 3 of 3
      • Lower and raise the kickstand several times to check for looseness, bending, or instability
      • Inspect the mounting bolt and bracket to ensure they aren't simply loose.
      Ask FixBot
    2. Daymak Max S Kickstand Replacement: step 2, image 1 of 3 Daymak Max S Kickstand Replacement: step 2, image 2 of 3 Daymak Max S Kickstand Replacement: step 2, image 3 of 3
      • Carefully flip the bike upside down, resting it on its seat and handlebars.
      • Placing a towel or carpet piece underneath can prevents scratches to components.
      Ask FixBot
    3. Daymak Max S Kickstand Replacement: step 3, image 1 of 3 Daymak Max S Kickstand Replacement: step 3, image 2 of 3 Daymak Max S Kickstand Replacement: step 3, image 3 of 3
      • Remove the 2 bolt securing the kickstand, typically near the rear wheel, using an Allen key or wrench
      Ask FixBot
    4. Daymak Max S Kickstand Replacement: step 4, image 1 of 3 Daymak Max S Kickstand Replacement: step 4, image 2 of 3 Daymak Max S Kickstand Replacement: step 4, image 3 of 3
      • Slide the old, damaged kickstand out of its mounting bracket.
      • If you plan to reuse the original bolt and washer, set them aside in a safe place.
      Ask FixBot
    5. Daymak Max S Kickstand Replacement: step 5, image 1 of 3 Daymak Max S Kickstand Replacement: step 5, image 2 of 3 Daymak Max S Kickstand Replacement: step 5, image 3 of 3
      • Align the new kickstand with the mounting bracket.
      • Insert the bolt through the bracket and kickstand.
      • Tighten the bolt securely using your Allen key (or wrench).
      • Ensure it's snug but be careful not to over-tighten and strip the threads.
      Ask FixBot
    6. Daymak Max S Kickstand Replacement: step 6, image 1 of 3 Daymak Max S Kickstand Replacement: step 6, image 2 of 3 Daymak Max S Kickstand Replacement: step 6, image 3 of 3
      • Carefully return the bike to its upright position.
      • Lower the kickstand on a level surface to verify it supports the bike's weight.
      • Retract the kickstand to ensure it springs back smoothly without hitting the wheel, chain, or frame.
      Ask FixBot
Finish Line
Thanh Dinh
133 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 29
All Time: 189
