Datawind Ubislate 7ci Rear Facing Camera Replacement
    1. Datawind Ubislate 7ci Rear Facing Camera Replacement, Finding a work space: step 1, image 1 of 1
      • Be sure to repair your device on a clean surface so you are less likely to lose small parts.
      Ask FixBot
    2. Datawind Ubislate 7ci Rear Facing Camera Replacement, Pry open your tablet: step 2, image 1 of 2 Datawind Ubislate 7ci Rear Facing Camera Replacement, Pry open your tablet: step 2, image 2 of 2
      • Run your prying tool along the front edge of the device to pop off the front cover.
      • Once the halves are separated your device should look like this.
      • (HINT: be careful of the device's small wiring when separating the two halves.)
      Ask FixBot
    3. Datawind Ubislate 7ci Rear Facing Camera Replacement, Removing the tape around the camera: step 3, image 1 of 2 Datawind Ubislate 7ci Rear Facing Camera Replacement, Removing the tape around the camera: step 3, image 2 of 2
      • Remove the black tape that is circled.
      • The camera is circled in this picture.
      Ask FixBot
    4. Datawind Ubislate 7ci Rear Facing Camera Replacement, Removing the camera: step 4, image 1 of 2 Datawind Ubislate 7ci Rear Facing Camera Replacement, Removing the camera: step 4, image 2 of 2
      • Carefully remove the camera from its housing.
      Ask FixBot
    5. Datawind Ubislate 7ci Rear Facing Camera Replacement, Inserting the Replacement Camera: step 5, image 1 of 2 Datawind Ubislate 7ci Rear Facing Camera Replacement, Inserting the Replacement Camera: step 5, image 2 of 2
      • Slide the new camera into its housing carefully.
      • it should look like the second picture when you are finished
      Ask FixBot
    6. Datawind Ubislate 7ci Rear Facing Camera Replacement, Closing the Tablet: step 6, image 1 of 1
      • Press the back cover of the tablet on firmly until it clicks
      Ask FixBot
2 other people completed this guide.
Mekides
40 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 23
All Time: 612
