Datawind Ubislate 7ci Battery Replacement
    1. Datawind Ubislate 7ci Battery Replacement, Battery: step 1, image 1 of 2 Datawind Ubislate 7ci Battery Replacement, Battery: step 1, image 2 of 2
      • Run your prying tool along the front edge of the device to pop off the front cover.
      • Once the halves are separated your device should look like this.
      • Be careful of the device's small wiring when separating the two halves.
      Ask FixBot
    2. Datawind Ubislate 7ci Battery Replacement: step 2, image 1 of 3 Datawind Ubislate 7ci Battery Replacement: step 2, image 2 of 3 Datawind Ubislate 7ci Battery Replacement: step 2, image 3 of 3
      • Remove the black tape.
      • Be careful not to remove the tablet camera.
      Ask FixBot
    3. Datawind Ubislate 7ci Battery Replacement: step 3, image 1 of 3 Datawind Ubislate 7ci Battery Replacement: step 3, image 2 of 3 Datawind Ubislate 7ci Battery Replacement: step 3, image 3 of 3
      • Use a soldering iron to remove the battery from both its attachment points.
      • Pry off the battery using an opening tool.
      Ask FixBot
    4. Datawind Ubislate 7ci Battery Replacement, Replacing the Battery: step 4, image 1 of 2 Datawind Ubislate 7ci Battery Replacement, Replacing the Battery: step 4, image 2 of 2
      • Insert your replacement battery in the same spot as the old battery.
      • Tape battery into place.
      Ask FixBot
    5. Datawind Ubislate 7ci Battery Replacement, Closing the Tablet: step 5, image 1 of 2 Datawind Ubislate 7ci Battery Replacement, Closing the Tablet: step 5, image 2 of 2
      • Solder the new battery to the connection points.
      • Press the back cover on firmly until it clicks.
      Ask FixBot
6 other people completed this guide.
Mekides
40 Reputation
3 Guides authored
2 Guide Comments
On my 7Ci the battery is SFH-HLKJ-204.
Datawind doesn't sale those pieces.
Where can I find one?
What type is it, voltage and so?
THX!
ylco - Reply Share
3.7V, 2200mAh lithium ion. Yiu can get a bigger or smaller one depending on shat you want.
Jessica Parnelli Fawkes - Reply Share
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 39
All Time: 9,718
