Dashcam DOD LS300W Battery Replacement
    1. Dashcam DOD LS300W Battery Replacement, This is the dashcam DOD LS300W: step 1, image 1 of 3 Dashcam DOD LS300W Battery Replacement, This is the dashcam DOD LS300W: step 1, image 2 of 3 Dashcam DOD LS300W Battery Replacement, This is the dashcam DOD LS300W: step 1, image 3 of 3
      • Using an opening tool, pry open the seam on the bottom of the dash cam to separate the two parts of the device.
      Ask FixBot
    2. Dashcam DOD LS300W Battery Replacement: step 2, image 1 of 2 Dashcam DOD LS300W Battery Replacement: step 2, image 2 of 2
      • Notice the connection of + and - on the top left side of the inside of the dash cam. Make note of this as it will be important to remember when you solder on the new battery.
      • Desolder the old battery. This is a 250mAh.
      Ask FixBot
    3. Dashcam DOD LS300W Battery Replacement: step 3, image 1 of 3 Dashcam DOD LS300W Battery Replacement: step 3, image 2 of 3 Dashcam DOD LS300W Battery Replacement: step 3, image 3 of 3
      • The new battery is 400mAh. and fits just in the battery location.
      • Solder in the new battery.
      • Then place the new battery into the space previously occupied by the old battery.
      • See the difference between old and new battery.
      • Be careful to solder the positive side of the new battery into the same spot that the old battery was soldered into.
      Ask FixBot
    4. Dashcam DOD LS300W Battery Replacement: step 4, image 1 of 1
      • Put the dashcam back together.
      • Charge the battery to the full level, and you are ready to go.
      Ask FixBot
Once again, thank you for checking out this guide and I hope it helped!
2 other people completed this guide.
Pierre
674 Reputation
4 Guides authored
2 Guide Comments
Hi mate, where did you buy the replacement battery from? I'm having trouble finding something online? blackdogwood@bigpond.com
Cheers,
Russell Edwards - Reply Share
Hi Russell, I found this battery on Ebay.
Good luck.
Cheers.
Pierre - Reply Share
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 46
All Time: 7,332
