Dangle Earrings Jump Ring Replacement
    1. Dangle Earrings Jump Ring Replacement, Jump Ring: step 1, image 1 of 1
      • Locate where the earring stud/hook has detached.
      • Look at the two pieces of the dangle earrings for a small loop or jump ring on both pieces.
      Ask FixBot
    2. Dangle Earrings Jump Ring Replacement: step 2, image 1 of 1
      • Using a chain nose plier, carefully grip the jump ring by its side.
      • Use a cutting plier to cut a small opening in the loop.
      Ask FixBot
    3. Dangle Earrings Jump Ring Replacement: step 3, image 1 of 1
      • With both pliers use the cutting plier to gently grip the side of the small jump ring.
      • Using the small nose chain pliers pull back on the small jump ring to create an opening.
      Ask FixBot
    4. Dangle Earrings Jump Ring Replacement: step 4, image 1 of 1
      • With the small chain nose pliers grip the jump ring.
      • Insert the stud/hook portion of the earring into the jump ring.
      Ask FixBot
    5. Dangle Earrings Jump Ring Replacement: step 5, image 1 of 1
      • Use the jump ring to reattach the the stud.
      • Insert the main portion of the earring into the jump ring with the stud/hoop.
      Ask FixBot
    6. Dangle Earrings Jump Ring Replacement: step 6, image 1 of 1
      • Use both pliers to close the loop.
      • Firmly grip the edge of the loop using a pair of cutting pliers.
      • With a pair of small chain grip pliers gently push the end of the jump ring forward to close the loop.
      Ask FixBot
    7. Dangle Earrings Jump Ring Replacement: step 7, image 1 of 1
      • Gently tug on either side of the earring to ensure the loop is closed securely.
      • If this test fails, refer back to step 6.
      Ask FixBot
Angelika Dela Torre
145 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 11
Past 30 Days: 56
All Time: 1,033
