Up to 20% off select tools
Danger Hiptop Battery Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
21
Past 30 Days:
98
All Time:
904
Comments: 7
7 guide comments.
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 2 hours
Difficulty: Moderate
Community-Contributed Guide
Parts
Tools
Introduction
Go to step 1 ↓
Here's a complete guide to replacing the battery in your first generation (2002) Danger Hiptop Sidekick. Nearly all of these phones will have a completely dead battery that cannot be charged. Details are provided on how to select a replacement battery, and what kind of charger to use.
This guide may work for the later color screen version of first generation, but will not work for later generations.
    1. Danger Hiptop Battery Replacement, Opening the case: step 1, image 1 of 3 Danger Hiptop Battery Replacement, Opening the case: step 1, image 2 of 3 Danger Hiptop Battery Replacement, Opening the case: step 1, image 3 of 3
      • Remove one Torx T7 screw 6mm long from the back, then use a spludger to separate the back from the main case.
      Ask FixBot
    2. Danger Hiptop Battery Replacement, Disconnecting the antenna connector (Canada Fido model only): step 2, image 1 of 3 Danger Hiptop Battery Replacement, Disconnecting the antenna connector (Canada Fido model only): step 2, image 2 of 3 Danger Hiptop Battery Replacement, Disconnecting the antenna connector (Canada Fido model only): step 2, image 3 of 3
      • Skip this step if you have the U.S. T-Mobile model.
      • Locate the antenna connector. With a spludger, gently pry up under the connector where indicated, and it will pop off.
      Ask FixBot
    3. Danger Hiptop Battery Replacement, Removing the RF module: step 3, image 1 of 3 Danger Hiptop Battery Replacement, Removing the RF module: step 3, image 2 of 3 Danger Hiptop Battery Replacement, Removing the RF module: step 3, image 3 of 3
      • Remove the RF module as follows:
      • Remove a Phillips PH1 x 6mm screw from the left side of the black plastic bracket.
      • Remove a skinny Phillips PH0 x 7mm screw from the right side of the plastic bracket.
      • Slide the black plastic bracket carefully from underneath the display ribbon cable towards the left, and set it aside.
      • The RF module is now held by a clip at the bottom, a small round locator pin on the lower right, and a connector at the top edge, underneath. Use a spludger at the top edge to pry the RF module connector loose. It will pop off.
      • Now just lift and slide the RF module up, and will clear the tab at the bottom. Set the RF module aside.
      Ask FixBot
    4. Danger Hiptop Battery Replacement, Removing the antenna module (Canada Fido model only): step 4, image 1 of 2 Danger Hiptop Battery Replacement, Removing the antenna module (Canada Fido model only): step 4, image 2 of 2
      • Lift the antenna module out, and set it aside.
      Ask FixBot
    5. Danger Hiptop Battery Replacement, Remove the SIM card: step 5, image 1 of 2 Danger Hiptop Battery Replacement, Remove the SIM card: step 5, image 2 of 2
      • Remove the SIM card so that the front case can be removed.
      Ask FixBot
    6. Danger Hiptop Battery Replacement, Separating the front case: step 6, image 1 of 3 Danger Hiptop Battery Replacement, Separating the front case: step 6, image 2 of 3 Danger Hiptop Battery Replacement, Separating the front case: step 6, image 3 of 3
      • First remove the four screws indicated to release the front case.
      • Use a spludger to pry all the way around the front of the case to release it.
      • Be careful not to damage the thumb wheel board ribbon cable which is still attached.
      Ask FixBot
    7. Danger Hiptop Battery Replacement, Disconnecting the thumb wheel board connector: step 7, image 1 of 2 Danger Hiptop Battery Replacement, Disconnecting the thumb wheel board connector: step 7, image 2 of 2
      • Use a pair of tweezers to grip the thumb wheel board ribbon cable, and pull it straight up to disengage it. To replace it later, just use tweezers to press it straight down into the connector.
      Ask FixBot
    8. Danger Hiptop Battery Replacement, Disconnecting the battery: step 8, image 1 of 2 Danger Hiptop Battery Replacement, Disconnecting the battery: step 8, image 2 of 2
      • The battery is now able to be removed. Use a pair of tweezers to pull straight up on the battery ribbon cable.
      Ask FixBot
    9. Danger Hiptop Battery Replacement, Removing the battery plastic cover: step 9, image 1 of 2 Danger Hiptop Battery Replacement, Removing the battery plastic cover: step 9, image 2 of 2
      • Use a razor or Xacto knife to slice the blue plastic battery sleeve, and remove the battery from the sleeve. Slice along the side without the battery manager circuit board.
      Ask FixBot
    10. Danger Hiptop Battery Replacement, Battery part number and polarity: step 10, image 1 of 2 Danger Hiptop Battery Replacement, Battery part number and polarity: step 10, image 2 of 2
      • Here’s pictures of the original battery, which will read 0 volts as it’s long since been drained.
      • Battery polarity is as indicated.
      • Battery part number is Samsung SDI ICP653465A, 1200mAh nominal 3.6V Li-polymer with built-in protection board on the side of the battery
      • The part number 653465 means 6.5mm thick, 34mm wide, 65mm long. You'll find plenty of replacement batteries online that are 6.5mm thick and 34mm wide, but none 65mm long. Just select one that's less than 65mm long, and around 1200mAh.
      • A 1200mAh 653450 Li-polymer battery is readily available on eBay. Some replacement batteries claim to fit this model, but they must meet these dimensions.
      Ask FixBot
    11. Danger Hiptop Battery Replacement, Prepare the replacement battery: step 11, image 1 of 3 Danger Hiptop Battery Replacement, Prepare the replacement battery: step 11, image 2 of 3 Danger Hiptop Battery Replacement, Prepare the replacement battery: step 11, image 3 of 3
      • Batteries with side connections to the protection board do not seem to exist, so the original battery flex cable cannot be reused, and you’ll need to solder the new battery in place.
      • Cut the connector off one wire at a time so you don’t short the battery, strip just a few mm of insulation, twist and tin the wire ends.
      • Replace the blue plastic cover over the new battery, and seal with Mylar or electrical tape. Be sure to include the foam padding to keep the battery from moving around too much.
      Ask FixBot
    12. Danger Hiptop Battery Replacement, Install the new battery: step 12, image 1 of 3 Danger Hiptop Battery Replacement, Install the new battery: step 12, image 2 of 3 Danger Hiptop Battery Replacement, Install the new battery: step 12, image 3 of 3
      • Tin the two indicated pins on the battery connector, and solder each color wire as shown. These two pins supply power to the phone.
      • Place the battery back into the case, as shown in the last photo. The wires tuck under the battery.
      • Reassemble the phone in reverse order.
      Ask FixBot
    13. Danger Hiptop Battery Replacement, Turn it on!: step 13, image 1 of 1
      • Congratulations! Your Sidekick is now working. Enjoy.
      Ask FixBot
    14. Danger Hiptop Battery Replacement, A word about chargers: step 14, image 1 of 2 Danger Hiptop Battery Replacement, A word about chargers: step 14, image 2 of 2
      • A word about chargers. There is no documentation on this. The charging port is center positive (+), and uses a barrel connector that measures 3.45mm outside diameter. So a nominal 3.5mm barrel connector should work fine.
      • As for charging voltage, use a 5V source. Any 5V USB charging brick will work fine, but it’s best if it provides at least 350mA, since that’s what the phone draws initially. Most brick chargers deliver 1A.
      • Here’s a look at the connector, and a homemade charging cord.
      Ask FixBot
Author
with
Scott
193 Reputation
1 Guide authored
7 Guide Comments
So I've changed out the battery but it seems battery drains even while phone is off. Anyway to atop this. Have you had the same problem with battery draining even while the sidekick is off. Can't seem to get passed this unless I had a Micro on off ish button Switch to the battery
Antcap - Reply Share
I've worked on two of these, and one had the same problem you're having. I was not able to figure it out, only that it had something to do with the first six pin tiny MOSFET that turns the battery on and off. Wish I could be of more help, but without any documentation on this phone, we're stuck.
Scott - Reply Share
I've also cut the ribbon cable and still used the original ribbon cable so all the contacts are still being used as original was instead of soldering direct to the phone like this so I'm not sure.
BTW, the part number of that tiny six pin part is SIL3407-TP P-Channel MOSFET, they're available on Digikey. 30V/4.1A.
I successfully replaced it on another Danger phone.
Scott - Reply Share
I will say this about the design. Mating the boards together I suspect has corrupted the flash memory. I base this on I had one working, decided to disassemble it, then when it was all back together it had a ROM error come up on the screen. The fix is to reload the flash, but...there is no way to do that because it requires special software and passwords and none of that is available anywhere. In production, they mate the boards, and it's OK that the flash contents are corrupted because they haven't programmed it yet. Basic story is you'll be lucky to repair one of these. Also consider that the flash being damaged, the routines that put the phone to sleep may be damaged, so it may appear that the phone is off, but it could be running some random code burning power. A total lack of documentation and inability to flash these makes them very difficult to repair. The only thing I've thought of was to provide an external switch to disconnect power while mating the boards, then enable power. But..too late!
Scott - Reply Share
Past 24 Hours: 3
Past 7 Days: 21
Past 30 Days: 98
All Time: 904
