Daewoo KOC-9U0T Lightbulb Replacement
    1. Daewoo KOC-9U0T Lightbulb Replacement, Lightbulb: step 1, image 1 of 1
      • Never attempt to change the bulb in a microwave while the microwave is still plugged in or while power is being supplied.
      • Unplug the microwave from any wall outlets or power sources.
      Ask FixBot
    2. Daewoo KOC-9U0T Lightbulb Replacement: step 2, image 1 of 1
      • Examine your microwave to find the vent on the back of the microwave.
      • On other microwaves, there will be a vent located either in the front, side or bottom of the machine, depending on make, model, and mounting.
      Ask FixBot
    3. Daewoo KOC-9U0T Lightbulb Replacement: step 3, image 1 of 1
      • Remove the four 20 x 3" screws on the rear side of the microwave using a Phillips #0 screwdriver.
      Ask FixBot
    4. Daewoo KOC-9U0T Lightbulb Replacement: step 4, image 1 of 1
      • Lift off the service panel of the microwave and set it aside.
      • Do not attempt to change the light bulb from within the microwave's interior; always remove the vent panel and change the light bulb from within.
      Ask FixBot
    5. Daewoo KOC-9U0T Lightbulb Replacement: step 5, image 1 of 1
      • Locate the box that the halogen light is kept in.
      • Search for the light box that contains the bulb.
      Ask FixBot
    6. Daewoo KOC-9U0T Lightbulb Replacement: step 6, image 1 of 1
      • Remove the screws that hold the lightbox in place with a Phillips #0 screwdriver.
      Ask FixBot
    7. Daewoo KOC-9U0T Lightbulb Replacement: step 7, image 1 of 1
      • Unscrew and remove the light bulb from the socket on the lightbox.
      • Replace it with a new light bulb.
      • Screw the lightbox back into place on the frame of the microwave.
      Ask FixBot
    8. Daewoo KOC-9U0T Lightbulb Replacement: step 8, image 1 of 1
      • Replace the service panel and tighten down the screws.
      • Make sure you tighten the screws hard enough because if it the cover of the microwave is loose, then the radiations can harm your body.
      Ask FixBot
    9. Daewoo KOC-9U0T Lightbulb Replacement: step 9, image 1 of 1
      • Plug the microwave back in or reset the breaker.
      • You’re ready to see if your microwave has been repaired.
      Ask FixBot
    10. Daewoo KOC-9U0T Lightbulb Replacement: step 10, image 1 of 1
      • Open the microwave's door to test the new light bulb: If you’ve replaced the bulb correctly and the new bulb is working properly, then the light should go back on when you reopen the microwave’s door!
      Ask FixBot
4 other people completed this guide.
2 Guide Comments
This is'nt the KOC-9U0T.... i have the KOC-9U0T model and it looks nothing like the pictures in this guide....
explainet - Reply Share
I don't see what the problem is, microwave lighting systems are very similar to each other
Antonio De Angelis - Reply Share
Past 24 Hours: 2
Past 7 Days: 19
Past 30 Days: 61
All Time: 4,150
