DYMO LabelWriter 450 Eject Button Replacement
Views: 3.4K
View statistics:
Past 24 Hours:
3
Past 7 Days:
14
Past 30 Days:
89
All Time:
3,405
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
This is a guide for replacing the eject button on a DYMO LabelWriter 450.
Tools
  • Phillips #1 Screwdriver
    5
  • Spudger
    4.9
    1. DYMO LabelWriter 450 Eject Button Replacement, Back Plate: step 1, image 1 of 3 DYMO LabelWriter 450 Eject Button Replacement, Back Plate: step 1, image 2 of 3 DYMO LabelWriter 450 Eject Button Replacement, Back Plate: step 1, image 3 of 3
      • Make sure the device is unplugged. Then, turn over the device so that the label is readable.
      • Remove the two 15.7mm screws on the top of the device first, and then the two 26.5mm screws on the bottom (they are in the smaller holes and larger holes respectively) using a Phillips #1 screwdriver.
      • You need a spudger to orient the bottom screws so that they can be removed.
      Ask FixBot
    2. DYMO LabelWriter 450 Eject Button Replacement: step 2, image 1 of 2 DYMO LabelWriter 450 Eject Button Replacement: step 2, image 2 of 2
      • Once the Back Plate has been unscrewed, you will see the components from the top of the device plugged into the motherboard. You will only have 1-2 inches of clearance to unplug the components from the motherboard.
      • There are four components to unplug: the power cable connector, the two small no-fuss ribbon cable connectors, and the large no-fuss ribbon cable connector. The order does not matter.
      • This device has a blade located within the front panel. When handling the device, be careful not to touch the blade.
      Ask FixBot
    1. DYMO LabelWriter 450 Eject Button Replacement, Eject Button: step 3, image 1 of 1
      • Turn the device upright and lift the lid. Carefully pull off the side panel that has the eject button on it until the panel gives way.
      Ask FixBot
Jared Finkel
649 Reputation
5 Guides authored
USF Tampa, Team S1-G4, Leahy Fall 2018 Member of USF Tampa, Team S1-G4, Leahy Fall 2018
USFT-LEAHY-F18S1G4
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 14
Past 30 Days: 89
All Time: 3,405
