Up to 20% off select tools
DYMO LabelPOINT 100 Keypad Replacement
Views: 1.9K
View statistics:
Past 24 Hours:
4
Past 7 Days:
20
Past 30 Days:
92
All Time:
1,853
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Better Introduction
Improve this guide by completing or revising its introduction.
Parts
Tools
    1. DYMO LabelPOINT 100 Keypad Replacement, Remove Screws To The Access Panel: step 2, image 1 of 2 DYMO LabelPOINT 100 Keypad Replacement, Remove Screws To The Access Panel: step 2, image 2 of 2
      • Use Phillips #00 Screwdriver to remove the three screws that hold the upper portion of the access panel.
      • Remove the blade cutter assembly.
      • Use Phillips #00 Screwdriver to remove the last two screws located in the battery panel that holds the bottom portion of the access panel.
      Ask FixBot
    2. DYMO LabelPOINT 100 Keypad Replacement, Remove Access Panel: step 3, image 1 of 1
      • Gently remove the access panel from the right side of the device.
      • Some electrical wiring will be exposed and will not detach. Be careful not to damage any electrical wiring when removing access panel.
      Ask FixBot
    3. DYMO LabelPOINT 100 Keypad Replacement, Removing Circuit Board: step 4, image 1 of 2 DYMO LabelPOINT 100 Keypad Replacement, Removing Circuit Board: step 4, image 2 of 2
      • Use Phillips #00 Screwdriver to remove three screws that hold down the circuit board.
      • Gently lift the bottom of the circuit board, revealing the keypad.
      • Be careful not to damage any components on the circuit board when disassembling.
      Ask FixBot
    4. DYMO LabelPOINT 100 Keypad Replacement, Remove Keypad: step 5, image 1 of 1
      • Remove the keypad from the front facing cover
      • When installing the new keypad, make sure all buttons are correctly set in each hole so that each button can be pressed.
      Ask FixBot
Author
with
Mike Dam
201 Reputation
2 Guides authored
USF Tampa, Team 5-2, Mcgee Fall 2014 Member of USF Tampa, Team 5-2, Mcgee Fall 2014
USFT-MCGEE-F14S5G2
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 20
Past 30 Days: 92
All Time: 1,853
