DYMO LabelPOINT 100 Cutting Blade Replacement
Views: 3.3K
View statistics:
Past 24 Hours:
Past 7 Days:
22
Past 30 Days:
100
All Time:
3,267
Comments: 2
1 comment on steps, 1 guide comment.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 - 15 minutes
Difficulty: Moderate
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
    1. DYMO LabelPOINT 100 Cutting Blade Replacement, Rear Panel: step 1, image 1 of 3 DYMO LabelPOINT 100 Cutting Blade Replacement, Rear Panel: step 1, image 2 of 3 DYMO LabelPOINT 100 Cutting Blade Replacement, Rear Panel: step 1, image 3 of 3
      • Slide the panel release button.
      • Lift the panel.
      Ask FixBot
    2. DYMO LabelPOINT 100 Cutting Blade Replacement, Remove Label Tape Cassette: step 2, image 1 of 2 DYMO LabelPOINT 100 Cutting Blade Replacement, Remove Label Tape Cassette: step 2, image 2 of 2
      • Firmly press the cartridge release button with your finger.
      • You may need to hold the cassette and/or entire device still while pressing the button.
      • Lift the label tape cassette out of the device.
      Ask FixBot
    1. DYMO LabelPOINT 100 Cutting Blade Replacement, Blade Disassembly: step 3, image 1 of 3 DYMO LabelPOINT 100 Cutting Blade Replacement, Blade Disassembly: step 3, image 2 of 3 DYMO LabelPOINT 100 Cutting Blade Replacement, Blade Disassembly: step 3, image 3 of 3
      • Use Phillips #00 Screwdriver to disengage cutter from device
      • Remove cutter
      Ask FixBot
    2. DYMO LabelPOINT 100 Cutting Blade Replacement, Remove Blade: step 4, image 1 of 3 DYMO LabelPOINT 100 Cutting Blade Replacement, Remove Blade: step 4, image 2 of 3 DYMO LabelPOINT 100 Cutting Blade Replacement, Remove Blade: step 4, image 3 of 3
      • Use Phillips #00 screw to unscrew blade from blade cutter
      • Carefully remove blade. The blade is sharp and can be dangerous if not handled properly.
      • Replace blade
      Ask FixBot
Dustin Holifer
207 Reputation
2 Guides authored
USF Tampa, Team 5-2, Mcgee Fall 2014 Member of USF Tampa, Team 5-2, Mcgee Fall 2014
USFT-MCGEE-F14S5G2
4 Members
60 Guides authored
1 Guide Comment
dangerous? Really :) haha anyway nice review.
speedy - Reply Share
Past 24 Hours: 1
Past 7 Days: 22
Past 30 Days: 100
All Time: 3,267
