Community-Contributed Guide
Introduction
Go to step 1 ↓The DXO ONE is secured with a plastic casing, so marks will inevitably be left after disassembly. Please consider this before proceeding.
Before you begin, please ensure that the camera lens cap has been slid up to the top of the lens and that the camera is turned off.
Open the protective cover at the back of the camera to prepare for the next step.
Remove the memory card (if any) from the camera, then use a Phillips screwdriver to remove the 2.5mm screw located in the center.
Insert the tip of the pry bar into the gap in the casing and slide it around to loosen the latch.
Gently shake the black plastic casing while pulling it backward.
Remove the black plastic casing
Use a Phillips screwdriver to remove the 3mm screws from the side bracket of the OLED screen.
Raise the OLED screen.
Use a plastic pry bar to open the clips securing the ribbon cable.
Use a plastic pry bar to pry open the clips on the black ribbon cable.
Use tweezers to remove the black ribbon cable.
Remove the OLED screen
When reassembling your equipment, please follow the reverse order of the instructions.
Special thanks to these translators:
100%
Jun Huang Lin (小強) is helping us fix the world! Want to contribute?
Start translating ›
