Up to 20% off select tools
DROCON Ninja Camera Replacement
View statistics:
Past 24 Hours:
6
Past 7 Days:
14
Past 30 Days:
68
All Time:
789
Comments: 9
9 comments on steps.
Completed: 0
Favorites: 0
Time Required: 40 - 45 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
This guide will help you replace the camera on the DROCON Ninja DC-014. The drone’s camera provides live video to the user while in flight. If you’re unable to see the live video consider replacing the camera. To determine if the camera needs replacement check out the troubleshooting guide linked here. Remember to remove the battery before beginning any work on the drone. An opening tool and a Phillips 00 screwdriver are required for this repair.
    1. DROCON Ninja Camera Replacement, Battery: step 1, image 1 of 3 DROCON Ninja Camera Replacement, Battery: step 1, image 2 of 3 DROCON Ninja Camera Replacement, Battery: step 1, image 3 of 3
      • Make sure the drone is powered off before beginning the battery replacement.
      • To turn the drone off, press and hold the black button on the top of the drone until all lights are off.
      • Firmly grasp the battery tab between your thumb and index finger.
      • Pull the battery away from the drone's body
      Ask FixBot
    1. DROCON Ninja Camera Replacement, Casing: step 2, image 1 of 3 DROCON Ninja Camera Replacement, Casing: step 2, image 2 of 3 DROCON Ninja Camera Replacement, Casing: step 2, image 3 of 3
      • Using a Phillips #00 Screwdriver remove the eight 4mm screws on the bottom of the drone.
      Ask FixBot
    2. DROCON Ninja Camera Replacement: step 3, image 1 of 2 DROCON Ninja Camera Replacement: step 3, image 2 of 2
      • Gently pull white casing away from the black bottom casing
      Ask FixBot
    3. DROCON Ninja Camera Replacement: step 4, image 1 of 3 DROCON Ninja Camera Replacement: step 4, image 2 of 3 DROCON Ninja Camera Replacement: step 4, image 3 of 3
      • Insert the opening tool under one of the black plastic connector slots that connects the circuit-board to the casing.
      • Gently pull the opening tool toward you to disconnect the circuit-board from the plastic casing.
      Ask FixBot
    1. DROCON Ninja Camera Replacement, Camera: step 5, image 1 of 3 DROCON Ninja Camera Replacement, Camera: step 5, image 2 of 3 DROCON Ninja Camera Replacement, Camera: step 5, image 3 of 3
      • Use a Phillips #00 screwdriver to remove the 5mm screws connecting the front two motor arms to the drone's body.
      • Use your fingers to gently pull the white plastic discs out of the motor arms.
      Ask FixBot
    2. DROCON Ninja Camera Replacement: step 6, image 1 of 2 DROCON Ninja Camera Replacement: step 6, image 2 of 2
      • Grasp the motor arm and pull up and away from the drone's body.
      • Repeat this step for the other front motor arm.
      Ask FixBot
    3. DROCON Ninja Camera Replacement: step 7, image 1 of 3 DROCON Ninja Camera Replacement: step 7, image 2 of 3 DROCON Ninja Camera Replacement: step 7, image 3 of 3
      • Using the Phillips #00 screwdriver, remove the two 3mm screws on the control board.
      Ask FixBot
    4. DROCON Ninja Camera Replacement: step 8, image 1 of 3 DROCON Ninja Camera Replacement: step 8, image 2 of 3 DROCON Ninja Camera Replacement: step 8, image 3 of 3
      • Using the opening tool flip up the black plastic clamp that holds the camera wire to the circuit board.
      • Gently pull the camera out from the control board.
      Ask FixBot
Author
with
Destinee Easterly
283 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 14
Past 30 Days: 68
All Time: 789
