Up to 20% off select tools
DRECELL VC021 Battery Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
9
Past 30 Days:
61
All Time:
496
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 30 - 45 minutes
Difficulty: Difficult
Tools
Introduction
Go to step 1 ↓
If you are experiencing battery and suction issues with your Drecell VC021, the culprit might be a faulty battery leading to a decline in power. This guide details a replacement method for the battery.
    1. DRECELL VC021 Battery Replacement, Battery: step 1, image 1 of 3 DRECELL VC021 Battery Replacement, Battery: step 1, image 2 of 3 DRECELL VC021 Battery Replacement, Battery: step 1, image 3 of 3
      • Use a Jimmy to pry open the panel to access the battery.
      Ask FixBot
    2. DRECELL VC021 Battery Replacement: step 2, image 1 of 3 DRECELL VC021 Battery Replacement: step 2, image 2 of 3 DRECELL VC021 Battery Replacement: step 2, image 3 of 3
      • Using a Phillips #00 screwdriver, remove the eight screws from the vacuum.
      Ask FixBot
    3. DRECELL VC021 Battery Replacement: step 3, image 1 of 3 DRECELL VC021 Battery Replacement: step 3, image 2 of 3 DRECELL VC021 Battery Replacement: step 3, image 3 of 3
      • Remove the motherboard simultaneously with the wire connecting to motor and the battery.
      Ask FixBot
    4. DRECELL VC021 Battery Replacement: step 4, image 1 of 3 DRECELL VC021 Battery Replacement: step 4, image 2 of 3 DRECELL VC021 Battery Replacement: step 4, image 3 of 3
      • Carefully remove the battery from the vacuum shell.
      Ask FixBot
Author
with
Charles
184 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 61
All Time: 496
