DR.J Professional HI-04 Lens Replacement
  1. DR.J Professional HI-04 Lens Replacement, Lens: step 1, image 1 of 3 DR.J Professional HI-04 Lens Replacement, Lens: step 1, image 2 of 3 DR.J Professional HI-04 Lens Replacement, Lens: step 1, image 3 of 3
    • Flip the projector so that the bottom is facing up.
    • Remove eight 10.0 mm screws from the back case with a Phillips #0 screwdriver.
    • The screws are set deep in the holes, so be careful not to drop them.
    • Remove two 20.0 mm screws with a Phillips #0 screwdriver.
    Ask FixBot
  2. DR.J Professional HI-04 Lens Replacement: step 2, image 1 of 3 DR.J Professional HI-04 Lens Replacement: step 2, image 2 of 3 DR.J Professional HI-04 Lens Replacement: step 2, image 3 of 3
    • Flip the projector so it is upright.
    • Remove the top case of the projector.
    • The shell of the projector should lift up easily but is fragile, so be gentle while lifting.
    • The top case is connected to the motherboard by cables, so avoid yanking it off to prevent snapping the connectors or damaging components.
    Ask FixBot
  3. DR.J Professional HI-04 Lens Replacement: step 3, image 1 of 2 DR.J Professional HI-04 Lens Replacement: step 3, image 2 of 2
    • Gently lift the black flap off from the base of the lens.
    Ask FixBot
  4. DR.J Professional HI-04 Lens Replacement: step 4, image 1 of 2 DR.J Professional HI-04 Lens Replacement: step 4, image 2 of 2
    • Remove the lens from the projector.
    • The lens is no longer secured but might still be tightly in place. Be gentle while removing it.
    Ask FixBot
  5. DR.J Professional HI-04 Lens Replacement: step 5, image 1 of 2 DR.J Professional HI-04 Lens Replacement: step 5, image 2 of 2
    • Unscrew the cover of the lens.
    Ask FixBot
Kory Lajoie
196 Reputation
1 Guide authored
UMass Dartmouth, Team 1-5, Petersen Fall 2023 Member of UMass Dartmouth, Team 1-5, Petersen Fall 2023
UMASSD-PETERSEN-F23S1G5
4 Members
5 Guides authored
1 Guide Comment
how to replace lcd
Rael Sañosa - Reply Share
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 66
All Time: 1,624
