Up to 20% off select tools
DOSS SoundBox Speaker Replacement
Views: 4.1K
View statistics:
Past 24 Hours:
4
Past 7 Days:
15
Past 30 Days:
85
All Time:
4,056
Comments: 2
1 comment on steps, 1 guide comment.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 25 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
In the case of a faulty speaker, use this guide to remove the speaker on the DOSS Soundbox for replacement.
Removing the speaker properly allows you to be able to install a new speaker to improve the quality of the speaker for better listening.
For this project you will need a Soldering Iron and knowledge on how to safely use this tool. Soldering Irons can be very hot so its important to use this took properly and take proper measures to protect yourself from the heat it produces.
    1. DOSS SoundBox Speaker Replacement, Speaker: step 1, image 1 of 2 DOSS SoundBox Speaker Replacement, Speaker: step 1, image 2 of 2
      • Use the JIS #00 screwdriver to remove the 3/32" screws that secure the speaker to the body.
      • Remove the smaller 3/32" screws that secure the left side of the speaker with a JIS #1 screwdriver.
      • The smaller screws are still the same length, but they have smaller screw heads. You can use the same screwdriver for both.
      • Using a Magnetic Mat throughout this process will help prevent losing screws.
      Ask FixBot
    2. DOSS SoundBox Speaker Replacement: step 2, image 1 of 2 DOSS SoundBox Speaker Replacement: step 2, image 2 of 2
      • Use the Plastic Opening Tool to gently lift the speaker enough to see the connected wires.
      Ask FixBot
    3. DOSS SoundBox Speaker Replacement: step 3, image 1 of 2 DOSS SoundBox Speaker Replacement: step 3, image 2 of 2
      • Use a soldering iron to de-solder the two speaker wires from the speaker itself.
      • The speakers are ready to be removed and replaced.
      • Ensure that the device is turned off when handling bare wire.
      • Soldering iron is very hot.
      Ask FixBot
To reassemble your device, follow instructions in reverse order.
2 other people completed this guide.
Author
with
Brendan Harkreader
566 Reputation
3 Guides authored
1 Guide Comment
The instructions say: "The speakers are ready to be removed and replaced." But nowhere in this article am I told where to get replacement speakers. Am I just on my own for that? This website has always been so helpful in providing links for such things. :(
Janie Thurman - Reply Share
Past 24 Hours: 4
Past 7 Days: 15
Past 30 Days: 85
All Time: 4,056
