Up to 20% off select tools
DOSS SoundBox Battery Replacement
Views: 16K
View statistics:
Past 24 Hours:
12
Past 7 Days:
39
Past 30 Days:
211
All Time:
15,836
Comments: 8
3 comments on steps, 5 guide comments.
Go to guide comments
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 40 minutes
Difficulty: Moderate
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
    1. DOSS SoundBox Battery Replacement, Battery: step 1, image 1 of 2 DOSS SoundBox Battery Replacement, Battery: step 1, image 2 of 2
      • Use a JIS #00 screwdriver to remove the four 3/32" screws that attach the base-plate to the speaker enclosure.
      • Use a magnetic mat to prevent the loss of screws.
      Ask FixBot
    2. DOSS SoundBox Battery Replacement: step 2, image 1 of 2 DOSS SoundBox Battery Replacement: step 2, image 2 of 2
      • Use a JIS #1 screwdriver to remove the six 3/32" screws marked with a red circle.
      • Remove the two 1/16" screws marked with orange circles using a JIS #000 screwdriver.
      Ask FixBot
    3. DOSS SoundBox Battery Replacement: step 3, image 1 of 1
      • Remove the six 3/32" screws marked with red circles using a JIS #00 screwdriver.
      • Remove the larger 3/32" screw indicated by an orange circle using a JIS #1 screwdriver.
      • Once the screws are removed, gently lift the top (where the touch controls are) off of the speaker.
      Ask FixBot
    4. DOSS SoundBox Battery Replacement: step 4, image 1 of 1
      • De-solder the connections from the battery to the circuit board.
      • If you do not already have a replacement battery, you can purchase one here.
      Ask FixBot
5 other people completed this guide.
Author
with
Brendan Harkreader
566 Reputation
3 Guides authored
5 Guide Comments
What could be the cause that the box works perfectly on low volume, but as soon as I raise the volume the box shuts down?
Thanks so much for your work here. :)
Milad Etemadi - Reply Share
Hi. Thanks for the guide! Can you please let me know how to remove the existing batt, I don’t know if it’s glued or sthing but I can’t take it out, I m stuck there. Tks !!
Philly newrocker - Reply Share
Did you manage to get it removed? I don’t know any more details than what this guide offered, but if it is glued in, isopropyl alcohol or some low heat are usually quite helpful. Make sure the battery is drained beforehand, of course, though I doubt it’ll be an issue since you’re trying to replace the battery, most likely because it’s not holding a charge anymore. If you use isopropyl, you can get fairly liberal with it without having to worry about damaging anything so long as you don’t get any on the speakers because the glue used to hold them together can desolve causing separation which would ruin the sound and would need repair.
Thousand Sunny - Reply Share
Link for Battery Replacement is broken.
Michael Scibetta - Reply Share
I believe this is the new link to replacement battery
Tenergy-37-2200-pcb
Fixer245 - Reply Share
Past 24 Hours: 12
Past 7 Days: 39
Past 30 Days: 211
All Time: 15,836
