Up to 20% off select tools
DOSS SoundBox Base-plate Replacement
Views: 3K
View statistics:
Past 24 Hours:
3
Past 7 Days:
15
Past 30 Days:
85
All Time:
2,977
Comments: 1
1 guide comment.
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 15 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
This guide will help you replace or remove the base plate on your DOSS SoundBox portable Bluetooth speaker, which provides structural integrity and protects the device's internal components. The base plate may need replacement if your speaker shows signs of physical instability or sound distortion coming from the base of the speaker. Before starting, ensure the device is powered off to avoid accidental damage.
    1. DOSS SoundBox Base-plate Replacement, Base-plate: step 1, image 1 of 3 DOSS SoundBox Base-plate Replacement, Base-plate: step 1, image 2 of 3 DOSS SoundBox Base-plate Replacement, Base-plate: step 1, image 3 of 3
      • Locate the four 3/32" screws on the bottom of your device.
      • Using a JIS #00 screwdriver, remove the four 3/32" screws.
      • After removing the screws, lift the cover off of the device.
      Ask FixBot
    2. DOSS SoundBox Base-plate Replacement: step 2, image 1 of 1
      • Using a JIS #1 screwdriver, remove the six 3/32" screws that attach the base-plate to the speaker enclosure. These screws are marked with red circles.
      • Using a JIS #000 screwdriver, remove the two 1/16" screws from the areas marked with an orange circle.
      • Having the magnetic pad handy will be beneficial, as these screws are very small and easily lost.
      Ask FixBot
    3. DOSS SoundBox Base-plate Replacement: step 3, image 1 of 1
      • Lift the base-plate off of the enclosure.
      Ask FixBot
3 other people completed this guide.
Author
with
Brendan Harkreader
566 Reputation
3 Guides authored
1 Guide Comment
Speaker had an unusual sound. Followed guide, really easy to work on. Diagnosis broken speaker membrane.
Albi No - Reply Share
Past 24 Hours: 3
Past 7 Days: 15
Past 30 Days: 85
All Time: 2,977
