Tools
Introduction
Go to step 1 ↓In this guide we will show you a step-by-step replacement guide for the Motherboard. You want to be careful when unplugging the speakers and battery from the board itself in order to not damage any of the wires.
The motherboard contains the following components:
Power Switch
Bluetooth sensor
Auxiliary port
Charging Port
Using Blue Plastic opening tool pry the top rubber cover, then using the same tool remove the bottom panel
Remove the single screw holding the motherboard to the front panel (Screw : Head PH1, Size .5 cm)
10 other people completed this guide.
21 Guide Comments
Where can I buy a replacement DKnight MagicBox II Motherboard ?
My Charge Port is not working, do I need to replace the Motherboard or is there a fix for the charge port? Verified that the cable is good. It use to work if I wiggled and applied pressure to one side. Verified port is clean.
Where do you get the replacement motherboard?!
I did the steps and the power still won't turn on. The blue light will turn on for a blink then nothing
mine is doing same thing. DKnight said they wont do anything because i bought it off Ebay and not Amazon.
