DJI Spark Lid Replacement
Views: 1.6K
View statistics:
Past 24 Hours:
Past 7 Days:
17
Past 30 Days:
69
All Time:
1,606
Comments: 3
3 comments on steps.
Completed: 0
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 2 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
Follow this guide to remove the lid on your DJI Spark. The lid needs to be removed to get access to the internals. The propellers and battery need to be taken out first before proceeding with detaching the lid. It is an easy 5-step process that can be done in less than 30 seconds.
Tools
    1. DJI Spark Lid Replacement, Propellers: step 1, image 1 of 1
      • Push down on the propeller that is being replaced.
      Ask FixBot
    2. DJI Spark Lid Replacement: step 2, image 1 of 2 DJI Spark Lid Replacement: step 2, image 2 of 2
      • Twist the propeller until it feels loose.
      • Pull on it until it comes off.
      Ask FixBot
    1. DJI Spark Lid Replacement, Battery: step 3, image 1 of 3 DJI Spark Lid Replacement, Battery: step 3, image 2 of 3 DJI Spark Lid Replacement, Battery: step 3, image 3 of 3
      • Flip the drone over.
      • Grip the left and right sides of the battery.
      • Slide firmly forward until it pops out.
      Ask FixBot
    1. DJI Spark Lid Replacement, Lid: step 4, image 1 of 3 DJI Spark Lid Replacement, Lid: step 4, image 2 of 3 DJI Spark Lid Replacement, Lid: step 4, image 3 of 3
      • Remove the four 1.5mm Hex screws.
      • Remove the two 1.5mm Hex screws near the camera head.
      • You may need to remove plastic nubs from the hex screws using a spudger first.
      Ask FixBot
    2. DJI Spark Lid Replacement: step 5, image 1 of 3 DJI Spark Lid Replacement: step 5, image 2 of 3 DJI Spark Lid Replacement: step 5, image 3 of 3
      • Hold the drone so the lid is facing up.
      • Insert the plastic opening tool into the side of the drone.
      • Slide the tool around the perimeter until you can lift the top off.
      Ask FixBot
Uzochi Anyanwu
534 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 17
Past 30 Days: 69
All Time: 1,606
