DJI Phantom 4 Advanced Remote Controller Motherboard Replacement
    1. DJI Phantom 4 Advanced Remote Controller Motherboard Replacement, Back Panel: step 1, image 1 of 1
      • Remove the four screws with a Torx T8 screwdriver to access the back con board.
      Ask FixBot
    2. DJI Phantom 4 Advanced Remote Controller Motherboard Replacement: step 2, image 1 of 2 DJI Phantom 4 Advanced Remote Controller Motherboard Replacement: step 2, image 2 of 2
      • Remove three screws using a Phillips #00 screwdriver.
      Ask FixBot
    3. DJI Phantom 4 Advanced Remote Controller Motherboard Replacement: step 3, image 1 of 2 DJI Phantom 4 Advanced Remote Controller Motherboard Replacement: step 3, image 2 of 2
      Tool used on this step:
      Buy
      • With tweezers, gently remove the large con board tab.
      • Use your hands to remove the two small clips. Pull out from the socket, in a horizontal direction.
      Ask FixBot
    4. DJI Phantom 4 Advanced Remote Controller Motherboard Replacement: step 4, image 1 of 2 DJI Phantom 4 Advanced Remote Controller Motherboard Replacement: step 4, image 2 of 2
      • Peel off the rubber grips to access the screw holes.
      • Make sure to save your grips and do not to get them stuck to anything, you are going to want to save the adhesive.
      • Remove the back board and set it aside.
      Ask FixBot
    5. DJI Phantom 4 Advanced Remote Controller Motherboard Replacement: step 5, image 1 of 2 DJI Phantom 4 Advanced Remote Controller Motherboard Replacement: step 5, image 2 of 2
      • Pull apart the back plastic panel.
      • Recommended tool for this would be the metal spudger, but not required.
      • Once the back panel is off, you will have access to the motherboard.
      Ask FixBot
    1. DJI Phantom 4 Advanced Remote Controller Motherboard Replacement, Motherboard: step 6, image 1 of 3 DJI Phantom 4 Advanced Remote Controller Motherboard Replacement, Motherboard: step 6, image 2 of 3 DJI Phantom 4 Advanced Remote Controller Motherboard Replacement, Motherboard: step 6, image 3 of 3
      • Disconnect ribbon tabs 1,2,5,8G, and 3.
      • Remove ribbon tab by pulling gently along motherboard. Do not pull straight out.
      • Then remove the plugs
      Ask FixBot
    2. DJI Phantom 4 Advanced Remote Controller Motherboard Replacement: step 7, image 1 of 2 DJI Phantom 4 Advanced Remote Controller Motherboard Replacement: step 7, image 2 of 2
      • With the Phillips #00 screwdriver, remove the two Phillips screws.
      Ask FixBot
    3. DJI Phantom 4 Advanced Remote Controller Motherboard Replacement: step 8, image 1 of 1
      • Double check to make sure all tabs, plugs and screws are removed or disconnected.
      • Gently lift motherboard out of the case.
      Ask FixBot
2 other people completed this guide.
2 Guide Comments
Do you know here can i buy a main board for phantom 4 advanced remote controller?
carl_darklife - Reply Share
I would like to know too, can’t find one anywhere
Luke James - Reply Share
Past 24 Hours: 0
Past 7 Days: 10
Past 30 Days: 43
All Time: 2,796
