DJI Phantom 4 Advanced Remote Controller Control Sticks Replacement
Views: 1.6K
View statistics:
Past 24 Hours:
2
Past 7 Days:
11
Past 30 Days:
78
All Time:
1,561
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 - 20 minutes
Difficulty: Difficult
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Introduction
Go to step 1 ↓
This guide will demonstrate step by step detailed instructions on how to safely remove and replace the Control Sticks of a DJI Phantom 4 Advanced Remote Controller. Since this operation will require to disconnect the motherboard is highly recommended to start this task with the appropriate tools on hand as well as enough time.
During this process s lot of connectors are required to be unplugged with caution to avoid damages to other parts , compromising the functionality of the remote controller.
Someone might need to replace the control sticks because of faultiness such as, inaccurate navigation, drifting directions without input, and control stick not functioning at all.
Parts
Tools
    1. DJI Phantom 4 Advanced Remote Controller Control Sticks Replacement, Back Panel: step 1, image 1 of 1
      • Remove the four screws with a Torx T8 screwdriver to access the back con board.
      Ask FixBot
    2. DJI Phantom 4 Advanced Remote Controller Control Sticks Replacement: step 2, image 1 of 2 DJI Phantom 4 Advanced Remote Controller Control Sticks Replacement: step 2, image 2 of 2
      • Remove three screws using a Phillips #00 screwdriver.
      Ask FixBot
    3. DJI Phantom 4 Advanced Remote Controller Control Sticks Replacement: step 3, image 1 of 2 DJI Phantom 4 Advanced Remote Controller Control Sticks Replacement: step 3, image 2 of 2
      Tool used on this step:
      Buy
      • With tweezers, gently remove the large con board tab.
      • Use your hands to remove the two small clips. Pull out from the socket, in a horizontal direction.
      Ask FixBot
    4. DJI Phantom 4 Advanced Remote Controller Control Sticks Replacement: step 4, image 1 of 2 DJI Phantom 4 Advanced Remote Controller Control Sticks Replacement: step 4, image 2 of 2
      • Peel off the rubber grips to access the screw holes.
      • Make sure to save your grips and do not to get them stuck to anything, you are going to want to save the adhesive.
      • Remove the back board and set it aside.
      Ask FixBot
    5. DJI Phantom 4 Advanced Remote Controller Control Sticks Replacement: step 5, image 1 of 2 DJI Phantom 4 Advanced Remote Controller Control Sticks Replacement: step 5, image 2 of 2
      • Pull apart the back plastic panel.
      • Recommended tool for this would be the metal spudger, but not required.
      • Once the back panel is off, you will have access to the motherboard.
      Ask FixBot
    1. DJI Phantom 4 Advanced Remote Controller Control Sticks Replacement, Motherboard: step 6, image 1 of 3 DJI Phantom 4 Advanced Remote Controller Control Sticks Replacement, Motherboard: step 6, image 2 of 3 DJI Phantom 4 Advanced Remote Controller Control Sticks Replacement, Motherboard: step 6, image 3 of 3
      • Disconnect ribbon tabs 1,2,5,8G, and 3.
      • Remove ribbon tab by pulling gently along motherboard. Do not pull straight out.
      • Then remove the plugs
      Ask FixBot
    2. DJI Phantom 4 Advanced Remote Controller Control Sticks Replacement: step 7, image 1 of 2 DJI Phantom 4 Advanced Remote Controller Control Sticks Replacement: step 7, image 2 of 2
      • With the Phillips #00 screwdriver, remove the two Phillips screws.
      Ask FixBot
    3. DJI Phantom 4 Advanced Remote Controller Control Sticks Replacement: step 8, image 1 of 1
      • Double check to make sure all tabs, plugs and screws are removed or disconnected.
      • Gently lift motherboard out of the case.
      Ask FixBot
    1. DJI Phantom 4 Advanced Remote Controller Control Sticks Replacement, Control Sticks: step 9, image 1 of 1
      • Remove the 10.7 mm Phillips screws using a Phillips #1 screwdriver.
      Ask FixBot
    2. DJI Phantom 4 Advanced Remote Controller Control Sticks Replacement: step 10, image 1 of 3 DJI Phantom 4 Advanced Remote Controller Control Sticks Replacement: step 10, image 2 of 3 DJI Phantom 4 Advanced Remote Controller Control Sticks Replacement: step 10, image 3 of 3
      • Gently remove the Gimbal Wheel control component from the body.
      • Take caution with the fragile wires when removing this component.
      Ask FixBot
    3. DJI Phantom 4 Advanced Remote Controller Control Sticks Replacement: step 11, image 1 of 2 DJI Phantom 4 Advanced Remote Controller Control Sticks Replacement: step 11, image 2 of 2
      • Remove the 4 10.7 mm Phillips screws using a Phillips #1 screwdriver.
      Ask FixBot
    4. DJI Phantom 4 Advanced Remote Controller Control Sticks Replacement: step 12, image 1 of 2 DJI Phantom 4 Advanced Remote Controller Control Sticks Replacement: step 12, image 2 of 2
      • Gently remove the Control Stick component.
      • Take caution with small and fragile wires to avoid breaking them.
      Ask FixBot
    5. DJI Phantom 4 Advanced Remote Controller Control Sticks Replacement: step 13, image 1 of 1
      • Repeat step 9 through 12 to remove the other Control Stick.
      Ask FixBot
IUPUI, Team S1-G1, Harley Summer 2019 Member of IUPUI, Team S1-G1, Harley Summer 2019
IUPUI-HARLEY-SU19S1G1
3 Members
24 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 11
Past 30 Days: 78
All Time: 1,561
