DJI Phantom 4 Advanced Remote Controller Back Con Board Replacement
    1. DJI Phantom 4 Advanced Remote Controller Back Con Board Replacement, Back Panel: step 1, image 1 of 1
      • Remove the four screws with a Torx T8 screwdriver to access the back con board.
      Ask FixBot
    2. DJI Phantom 4 Advanced Remote Controller Back Con Board Replacement: step 2, image 1 of 2 DJI Phantom 4 Advanced Remote Controller Back Con Board Replacement: step 2, image 2 of 2
      • Remove three screws using a Phillips #00 screwdriver.
      Ask FixBot
    3. DJI Phantom 4 Advanced Remote Controller Back Con Board Replacement: step 3, image 1 of 2 DJI Phantom 4 Advanced Remote Controller Back Con Board Replacement: step 3, image 2 of 2
      Tool used on this step:
      Buy
      • With tweezers, gently remove the large con board tab.
      • Use your hands to remove the two small clips. Pull out from the socket, in a horizontal direction.
      Ask FixBot
    4. DJI Phantom 4 Advanced Remote Controller Back Con Board Replacement: step 4, image 1 of 2 DJI Phantom 4 Advanced Remote Controller Back Con Board Replacement: step 4, image 2 of 2
      • Peel off the rubber grips to access the screw holes.
      • Make sure to save your grips and do not to get them stuck to anything, you are going to want to save the adhesive.
      • Remove the back board and set it aside.
      Ask FixBot
    5. DJI Phantom 4 Advanced Remote Controller Back Con Board Replacement: step 5, image 1 of 2 DJI Phantom 4 Advanced Remote Controller Back Con Board Replacement: step 5, image 2 of 2
      • Pull apart the back plastic panel.
      • Recommended tool for this would be the metal spudger, but not required.
      • Once the back panel is off, you will have access to the motherboard.
      Ask FixBot
    1. DJI Phantom 4 Advanced Remote Controller Back Con Board Replacement, Back Con Board: step 6, image 1 of 1
      • Remove the three PH0 screws securing the PCB to the remote.
      Ask FixBot
    2. DJI Phantom 4 Advanced Remote Controller Back Con Board Replacement: step 7, image 1 of 2 DJI Phantom 4 Advanced Remote Controller Back Con Board Replacement: step 7, image 2 of 2
      • Remove each of the three ribbon cables from their tabs by pulling in a horizontal direction away from the socket.
      • Remove the Back Con Board.
      Ask FixBot
    3. DJI Phantom 4 Advanced Remote Controller Back Con Board Replacement: step 8, image 1 of 1
      • The board can now be replaced.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 30
All Time: 1,461
