Up to 20% off select tools
DJI Phantom 4 Advanced Remote Controller Back Buttons Replacement
Views: 1.1K
View statistics:
Past 24 Hours:
3
Past 7 Days:
15
Past 30 Days:
82
All Time:
1,068
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 - 15 minutes
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Tools
Introduction
Go to step 1 ↓
This guide explains how to replace the back buttons on a DJI Phantom 4 Advanced Remote Controller, which shares a similar design with other Phantom 4‑series controllers such as the Phantom 4 Pro and Phantom 4 Pro+. In this repair, you will remove the worn or unresponsive rear function buttons and install new ones to restore full control over customizable flight features. These back buttons allow pilots to trigger key functions—such as camera settings, gimbal adjustments, or custom shortcuts—making them essential for smooth and efficient drone operation.
If your controller’s back buttons feel loose, fail to click, respond intermittently, or no longer activate assigned functions, they may be damaged or experiencing internal wear. Before proceeding, review the relevant sections of your user manual under the troubleshooting section (e.g., “Unresponsive Controller Buttons”, “Intermittent Input or Sticking Buttons”, “Controller Custom Function Not Triggering”) to confirm that the issue is hardware‑related rather than a software or calibration problem.
Because this repair requires opening the controller shell, follow all recommended safety precautions. Power off the controller completely, disconnect it from any charging source, and work in a clean, static‑safe environment. Use ESD‑safe tools to avoid damaging sensitive internal circuitry, and take care when separating parts from the controller to prevent strain or damage on ribbon cables, antennas, or internal wiring. Inspect the device for any signs of battery swelling, cracked housing, or damaged ports, which may require additional attention. Dispose of any broken components responsibly according to local e‑waste guidelines.
For additional background on controller hardware, button mechanisms, or safe electronics handling, you may find it helpful to consult DJI’s official support documentation, iFixit repair guides, or general electronics‑repair resources.
    1. DJI Phantom 4 Advanced Remote Controller Back Buttons Replacement, Back Panel: step 1, image 1 of 1
      • Remove the four screws with a Torx T8 screwdriver to access the back con board.
      Ask FixBot
    2. DJI Phantom 4 Advanced Remote Controller Back Buttons Replacement: step 2, image 1 of 2 DJI Phantom 4 Advanced Remote Controller Back Buttons Replacement: step 2, image 2 of 2
      • Remove three screws using a Phillips #00 screwdriver.
      Ask FixBot
    3. DJI Phantom 4 Advanced Remote Controller Back Buttons Replacement: step 3, image 1 of 2 DJI Phantom 4 Advanced Remote Controller Back Buttons Replacement: step 3, image 2 of 2
      Tool used on this step:
      Buy
      • With tweezers, gently remove the large con board tab.
      • Use your hands to remove the two small clips. Pull out from the socket, in a horizontal direction.
      Ask FixBot
    4. DJI Phantom 4 Advanced Remote Controller Back Buttons Replacement: step 4, image 1 of 2 DJI Phantom 4 Advanced Remote Controller Back Buttons Replacement: step 4, image 2 of 2
      • Peel off the rubber grips to access the screw holes.
      • Make sure to save your grips and do not to get them stuck to anything, you are going to want to save the adhesive.
      • Remove the back board and set it aside.
      Ask FixBot
    5. DJI Phantom 4 Advanced Remote Controller Back Buttons Replacement: step 5, image 1 of 2 DJI Phantom 4 Advanced Remote Controller Back Buttons Replacement: step 5, image 2 of 2
      • Pull apart the back plastic panel.
      • Recommended tool for this would be the metal spudger, but not required.
      • Once the back panel is off, you will have access to the motherboard.
      Ask FixBot
    1. DJI Phantom 4 Advanced Remote Controller Back Buttons Replacement, Back Buttons: step 6, image 1 of 2 DJI Phantom 4 Advanced Remote Controller Back Buttons Replacement, Back Buttons: step 6, image 2 of 2
      • Using a Phillips #00 screwdriver, remove the four screws on the inside of the panel. That will allow you to remove the buttons by gently lifting them with your hands.
      Ask FixBot
    2. DJI Phantom 4 Advanced Remote Controller Back Buttons Replacement: step 7, image 1 of 1
      • Remove back buttons and replace with new ones.
      Ask FixBot
Author
with
Angel Cortez
249 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 15
Past 30 Days: 82
All Time: 1,068
