Up to 20% off select tools
DJI Phantom 4 Advanced Flight Controller Replacement
Views: 4.5K
View statistics:
Past 24 Hours:
4
Past 7 Days:
19
Past 30 Days:
112
All Time:
4,542
Comments: 5
1 comment on steps, 4 guide comments.
Go to guide comments
Completed: 8
8 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 30 minutes - 1 hour
Difficulty: Difficult
Introduction
Go to step 1 ↓
The flight controller houses sensors and firmware that are critical to the drone’s functionality. If your drone experiences in-flight drifting or errors with the IMU after calibration, your flight controller board may need to be replaced. To replace the board, you need a JIS #000 screwdriver, a 2mm hex bit, a 1.5mm hex bit, and a metal prying tool. Take special care when removing and installing the U.FL connector.
    1. DJI Phantom 4 Advanced Flight Controller Replacement, Propeller: step 1, image 1 of 2 DJI Phantom 4 Advanced Flight Controller Replacement, Propeller: step 1, image 2 of 2
      • Use your finger tips to pinch the damaged propeller.
      • Twist the propeller counterclockwise and pull up to remove.
      Ask FixBot
    1. DJI Phantom 4 Advanced Flight Controller Replacement, Shell: step 2, image 1 of 2 DJI Phantom 4 Advanced Flight Controller Replacement, Shell: step 2, image 2 of 2
      • Remove the eight 7 mm hex screws by turning counterclockwise with a 2 mm hex bit.
      Ask FixBot
    2. DJI Phantom 4 Advanced Flight Controller Replacement: step 3, image 1 of 1
      • Pry the LED motor covers off with a metal spudger.
      • The prying location is marked by an indent that points outward from the arm.
      Ask FixBot
    3. DJI Phantom 4 Advanced Flight Controller Replacement: step 4, image 1 of 1
      • Pry the paper covering off the four corners with a metal spudger.
      Ask FixBot
    4. DJI Phantom 4 Advanced Flight Controller Replacement: step 5, image 1 of 1
      • Remove the twelve 8.7 mm hex screws with a 2 mm hex bit from the motor bases.
      Ask FixBot
    5. DJI Phantom 4 Advanced Flight Controller Replacement: step 6, image 1 of 2 DJI Phantom 4 Advanced Flight Controller Replacement: step 6, image 2 of 2
      • Flip the drone on its back
      • Remove the eight 4.5 mm hex screws by turning them counterclockwise with a 1.5 mm hex bit.
      • Separate the mesh from the drone by pulling up gently and rocking left to right.
      • The cable connects from the camera to the drone. Pulling up could rip the connection. Tilt the mesh 90 degrees towards the cable.
      Ask FixBot
    6. DJI Phantom 4 Advanced Flight Controller Replacement: step 7, image 1 of 1
      • Remove two 1.2mm screws using the JIS #000 bit from the camera cable retaining bracket.
      Ask FixBot
    7. DJI Phantom 4 Advanced Flight Controller Replacement: step 8, image 1 of 1
      • Lift the camera connector at one end with your hand and remove the mesh.
      Ask FixBot
    8. DJI Phantom 4 Advanced Flight Controller Replacement: step 9, image 1 of 3 DJI Phantom 4 Advanced Flight Controller Replacement: step 9, image 2 of 3 DJI Phantom 4 Advanced Flight Controller Replacement: step 9, image 3 of 3
      • Remove the two 1.2 mm screws using a JIS #000 bit from the antenna retaining bracket.
      • Pull the four U.FL antennae up.
      • The U.FL antenna connectors are fragile.
      • Remove the two 4 mm screws using a JIS #000 bit.
      Ask FixBot
    9. DJI Phantom 4 Advanced Flight Controller Replacement: step 10, image 1 of 2 DJI Phantom 4 Advanced Flight Controller Replacement: step 10, image 2 of 2
      • Pry apart the clamshell at the motor end.
      • Separate the clamshell.
      • Two wires connect from the lower frame to the upper frame at the front of the drone. Pulling the clamshell apart hard may damage the connectors and wires.
      Ask FixBot
    10. DJI Phantom 4 Advanced Flight Controller Replacement: step 11, image 1 of 1
      • Press the connector tabs with a spudger and pull on the wire simultaneously.
      • Remove the shell from the rest of the drone.
      Ask FixBot
    1. DJI Phantom 4 Advanced Flight Controller Replacement, Flight Controller: step 12, image 1 of 3 DJI Phantom 4 Advanced Flight Controller Replacement, Flight Controller: step 12, image 2 of 3 DJI Phantom 4 Advanced Flight Controller Replacement, Flight Controller: step 12, image 3 of 3
      Tool used on this step:
      Buy
      • Peel the electrical tape off.
      • Unlock the connector by prying up on the black latch.
      • Pull the ribbon cable out with tweezers.
      Ask FixBot
    2. DJI Phantom 4 Advanced Flight Controller Replacement: step 13, image 1 of 2 DJI Phantom 4 Advanced Flight Controller Replacement: step 13, image 2 of 2
      • Remove the flight controller vibration dampers by pushing the dampers into the mounts with the spudger.
      • Be careful not to tear the rubber isolators. Replace the rubber isolators if damaged.
      Ask FixBot
8 other people completed this guide.
Author
with
Ben Li
279 Reputation
1 Guide authored
Cal Poly, Team S15-G6, White Fall 2018 Member of Cal Poly, Team S15-G6, White Fall 2018
CPSU-WHITE-F18S15G6
4 Members
72 Guides authored
4 Guide Comments
Great guide but there should have been step 14 to show how to put the control board back on top of the isolators.
Also I found it was not necessary to remove the bottom shell to remove and replace the control board. There is enough room to remove and replace with the shell in place and this will greatly decrease the time required to do the repair. I used the rounded edge of a small flat screw driver.
The replacement of the board is a challenge and that is where I got stuck. I used monofilament fishing line. Make a loop in the line and insert the loop through the mounting hole in the board. Pass the loop over the isolator ball and into the groove around it. Bring the mounting board into contact with the isolator ball and gently pull the fishing line loop and pull the isolator ball up into the mounting hole. If you are lucky, the ball will come through and flatten itself out as is is supposed to. If not, use tweezers to grab the ball and gently pull it up through the hole.
MastaGzu - Reply Share
Thant for the
emeremnd - Reply Share
Excellent guide. This helped so much for me to replace my failed flight control board. I dropped one of the small screws and could not find it! I bought a DJI Phantom 4 fastener pack that has alot of these specialty screws. I only needed one screw, but now have lots of backups for future. An improvement to the instructions would be reassembly steps. It could help with some of the wire routing that I figured out the routing, but callouts would help. As a contribution to a possible update, I figured out a simple, reliable technique to push the dampener boots through the flight control board corners. Essentially use needle-nose pliers to squeeze the wide part of the dampener and push one end of the squished profile through the board hole. Use your other hand to pinch or roll the rest of the dampener through the hole. If allowed here is a link to a video showing how I did this: https://youtu.be/QHvy0n_iorE
Gerald Holt - Reply Share
Thanks for this. The visuals helped out a ton in knowing what to do. Like comments above mentioned, there is just enough room to do this without removing the entire shell. The dampeners were the hardest part to reinstall. I tried the fishing line trick commented above with no success so I brute forced it. I lined up the board with the dampeners, pushed down on the board to compress them and then took my tweezers and really forcefully grabbed them. Once one side was up, I dug my tweezers down into it to grab the opposite side through the hole. I got the rest of them done within 5 min doing it this way.
Steven King - Reply Share
Past 24 Hours: 4
Past 7 Days: 19
Past 30 Days: 112
All Time: 4,542
