DJI Phantom 3 Standard Battery Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
29
Past 30 Days:
118
All Time:
706
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 seconds
Difficulty: Very easy
Introduction
Go to step 1 ↓
This guide will show you how to remove the DJI Phantom 3 Standard's battery. It uses a 4‑cell LiPo battery specifically designed to power the drone during flight. Also known as DJI Phantom 3 Standard Intelligent Flight Battery (model number: PH3‑4480mAh‑15.2V).
You may need to remove the battery if it is not charging, if the drone fails to power on, or if you are replacing it with a new one. For more details on these issues, see the DJI Phantom 3 Standard Battery Does Not Charge troubleshooting page.
The Intelligent Flight Battery provides up to 25 minutes of flight time and includes built‑in sensors and protection circuits. Because it is a LiPo battery, it must be handled with care. Do not attempt to open, puncture, or crush the battery. If the battery appears swollen, damaged, or leaking, discontinue use immediately and dispose of it properly at a certified battery recycling facility.
Before beginning this guide, make sure the drone is powered off. Removing the battery while the drone is powered on can cause data loss or damage to internal components.
    1. DJI Phantom 3 Standard Battery Replacement, Battery: step 1, image 1 of 3 DJI Phantom 3 Standard Battery Replacement, Battery: step 1, image 2 of 3 DJI Phantom 3 Standard Battery Replacement, Battery: step 1, image 3 of 3
      • Pinch the battery's clamps on the top and bottom.
      • Pull out the battery.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 29
Past 30 Days: 118
All Time: 706
