Up to 20% off select tools
DJI Phantom 2 Vision+ Propellers Removal
Views: 7.9K
View statistics:
Past 24 Hours:
2
Past 7 Days:
22
Past 30 Days:
92
All Time:
7,932
Comments: 0
Go to guide comments
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 minutes
Difficulty: Very easy
Introduction
Go to step 1 ↓
Use this guide to replace a broken propellor on your DJI Phantom 2 Vision+. When replacing, be sure to match the original propellor spin direction.
Note: the drone used in this guide probably looks different from yours! It's just a custom paint job, otherwise it's completely stock.
    1. DJI Phantom 2 Vision+ Propellers Removal, Remove the battery: step 1, image 1 of 3 DJI Phantom 2 Vision+ Propellers Removal, Remove the battery: step 1, image 2 of 3 DJI Phantom 2 Vision+ Propellers Removal, Remove the battery: step 1, image 3 of 3
      • Pinch the top and bottom tabs of the battery case, pull the battery straight out to remove it.
      • The metal connectors form a stiff mechanical connection with the battery, you will need quite a bit of force to remove the battery. Hold the Phantom Vision+ with one hand and remove the battery with the other.
      Ask FixBot
    1. DJI Phantom 2 Vision+ Propellers Removal, Propellers: step 2, image 1 of 1
      • Determine if the propellor is clockwise or counter-clockwise rotating.
      • Each arm is labeled with a rotation icon that shows the direction of propellor rotation.
      • If this icon is missing or you can't read it, you can determine the direction of rotation by examining the propellor.
      • A clockwise rotating propellor pushes air down while rotating clockwise, and the opposite is true for a counter-clockwise rotating propellor, and the propellor blade slopes up in the direction of rotation.
      Ask FixBot
    2. DJI Phantom 2 Vision+ Propellers Removal, Removing clockwise rotating propellers: step 3, image 1 of 3 DJI Phantom 2 Vision+ Propellers Removal, Removing clockwise rotating propellers: step 3, image 2 of 3 DJI Phantom 2 Vision+ Propellers Removal, Removing clockwise rotating propellers: step 3, image 3 of 3
      • Loosen a clockwise rotating propeller by holding the motor with one hand and spinning the propellor clockwise.
      • Remove the propellor.
      Ask FixBot
    3. DJI Phantom 2 Vision+ Propellers Removal, Removing counter-clockwise rotating propellers: step 4, image 1 of 3 DJI Phantom 2 Vision+ Propellers Removal, Removing counter-clockwise rotating propellers: step 4, image 2 of 3 DJI Phantom 2 Vision+ Propellers Removal, Removing counter-clockwise rotating propellers: step 4, image 3 of 3
      • Loosen a counter-clockwise rotating propeller by holding the motor with one hand and spinning the propellor counter-clockwise.
      Ask FixBot
5 other people completed this guide.
Author
with
David Hoyt
4,053 Reputation
39 Guides authored
Cal Poly, Team 25-89, Amido Spring 2010 Member of Cal Poly, Team 25-89, Amido Spring 2010
CPSU-AMIDO-S10S25G89
4 Members
564 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 22
Past 30 Days: 92
All Time: 7,932
