Up to 20% off select tools
DJI Phantom 2 Vision+ Motor Removal
Views: 6.4K
View statistics:
Past 24 Hours:
3
Past 7 Days:
23
Past 30 Days:
107
All Time:
6,431
Comments: 0
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 7
7 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 30 minutes
Difficulty: Difficult
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Parts
Tools
Introduction
Go to step 1 ↓
Replace or upgrade your Phantom motors. This guide requires soldering. Each motor's direction is determined by the order of its leads on the ESC, so during the replacement, be sure to match the original order. Motors on opposite arms will have the same direction, so check the opposite arm for a wiring reference.
If you're ordering a replacement, be sure to get the right thread direction for your motor, or the propellor collet will loosen during flight.
Note: the drone used in this guide probably looks different from yours! It's just a custom paint job, otherwise it's completely stock.
    1. DJI Phantom 2 Vision+ Motor Removal, Remove the battery: step 1, image 1 of 3 DJI Phantom 2 Vision+ Motor Removal, Remove the battery: step 1, image 2 of 3 DJI Phantom 2 Vision+ Motor Removal, Remove the battery: step 1, image 3 of 3
      • Pinch the top and bottom tabs of the battery case, pull the battery straight out to remove it.
      • The metal connectors form a stiff mechanical connection with the battery, you will need quite a bit of force to remove the battery. Hold the Phantom Vision+ with one hand and remove the battery with the other.
      Ask FixBot
    1. DJI Phantom 2 Vision+ Motor Removal, Propellers: step 2, image 1 of 1
      • Determine if the propellor is clockwise or counter-clockwise rotating.
      • Each arm is labeled with a rotation icon that shows the direction of propellor rotation.
      • If this icon is missing or you can't read it, you can determine the direction of rotation by examining the propellor.
      • A clockwise rotating propellor pushes air down while rotating clockwise, and the opposite is true for a counter-clockwise rotating propellor, and the propellor blade slopes up in the direction of rotation.
      Ask FixBot
    2. DJI Phantom 2 Vision+ Motor Removal, Removing clockwise rotating propellers: step 3, image 1 of 3 DJI Phantom 2 Vision+ Motor Removal, Removing clockwise rotating propellers: step 3, image 2 of 3 DJI Phantom 2 Vision+ Motor Removal, Removing clockwise rotating propellers: step 3, image 3 of 3
      • Loosen a clockwise rotating propeller by holding the motor with one hand and spinning the propellor clockwise.
      • Remove the propellor.
      Ask FixBot
    3. DJI Phantom 2 Vision+ Motor Removal, Removing counter-clockwise rotating propellers: step 4, image 1 of 3 DJI Phantom 2 Vision+ Motor Removal, Removing counter-clockwise rotating propellers: step 4, image 2 of 3 DJI Phantom 2 Vision+ Motor Removal, Removing counter-clockwise rotating propellers: step 4, image 3 of 3
      • Loosen a counter-clockwise rotating propeller by holding the motor with one hand and spinning the propellor counter-clockwise.
      Ask FixBot
    1. DJI Phantom 2 Vision+ Motor Removal, Case Top Shell: step 5, image 1 of 2 DJI Phantom 2 Vision+ Motor Removal, Case Top Shell: step 5, image 2 of 2
      • Remove the following screws from the underside of the Phantom:
      • Twelve 2.0 mm hex bolts
      • Four Phillips #00 screws
      Ask FixBot
    2. DJI Phantom 2 Vision+ Motor Removal: step 6, image 1 of 2 DJI Phantom 2 Vision+ Motor Removal: step 6, image 2 of 2
      • Gently lift up the top shell case.
      • Do not attempt to fully remove the top shell. The GPS cable is still attached to the mainboard, avoid lifting the case too high or you may damage this connection.
      Ask FixBot
    3. DJI Phantom 2 Vision+ Motor Removal, Unplug GPS connector and remove case: step 7, image 1 of 3 DJI Phantom 2 Vision+ Motor Removal, Unplug GPS connector and remove case: step 7, image 2 of 3 DJI Phantom 2 Vision+ Motor Removal, Unplug GPS connector and remove case: step 7, image 3 of 3
      • The GPS cable molex connector is located on the backside of the mainboard, near the battery opening.
      • Pull the GPS connector straight up out of its socket.
      • Lift the top shell case up and remove it from the body of the Phantom.
      Ask FixBot
    1. DJI Phantom 2 Vision+ Motor Removal, Desolder motor wires: step 8, image 1 of 2 DJI Phantom 2 Vision+ Motor Removal, Desolder motor wires: step 8, image 2 of 2
      • Desolder all three motor wires.
      • When replacing a motor, be sure to solder the new motor in following the same wire color order as when you removed it.
      • The motor spin direction is dependent on the order of the wires, and may not match this image exactly. If you forgot the order, check the arm directly opposite for reference.
      Ask FixBot
    2. DJI Phantom 2 Vision+ Motor Removal: step 9, image 1 of 1
      • Remove the four 2mm hex motor bolts.
      Ask FixBot
    3. DJI Phantom 2 Vision+ Motor Removal: step 10, image 1 of 2 DJI Phantom 2 Vision+ Motor Removal: step 10, image 2 of 2
      • Remove the motor from the motor mount.
      Ask FixBot
4 other people completed this guide.
Author
with
David Hoyt
4,053 Reputation
39 Guides authored
Cal Poly, Team 25-89, Amido Spring 2010 Member of Cal Poly, Team 25-89, Amido Spring 2010
CPSU-AMIDO-S10S25G89
4 Members
564 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 23
Past 30 Days: 107
All Time: 6,431
