Up to 20% off select tools
DJI Phantom 2 Vision+ Battery Removal
Views: 3K
View statistics:
Past 24 Hours:
6
Past 7 Days:
23
Past 30 Days:
98
All Time:
3,014
Comments: 0
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
No tools are required to remove the battery from your DJI Phantom 2 Vision+. You should always remove the battery before servicing your Phantom to avoid electric shock or accidentally powering the propellors.
Note: the drone used in this guide probably looks different from yours! It's just a custom paint job, otherwise it's completely stock.
    1. DJI Phantom 2 Vision+ Battery Removal, Remove the battery: step 1, image 1 of 3 DJI Phantom 2 Vision+ Battery Removal, Remove the battery: step 1, image 2 of 3 DJI Phantom 2 Vision+ Battery Removal, Remove the battery: step 1, image 3 of 3
      • Pinch the top and bottom tabs of the battery case, pull the battery straight out to remove it.
      • The metal connectors form a stiff mechanical connection with the battery, you will need quite a bit of force to remove the battery. Hold the Phantom Vision+ with one hand and remove the battery with the other.
      Ask FixBot
3 other people completed this guide.
Author
with
David Hoyt
4,053 Reputation
39 Guides authored
Cal Poly, Team 25-89, Amido Spring 2010 Member of Cal Poly, Team 25-89, Amido Spring 2010
CPSU-AMIDO-S10S25G89
4 Members
564 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 23
Past 30 Days: 98
All Time: 3,014
