Confusing Text
Some of this guide's text is confusing, duplicated, or off-topic. Clarify it by editing!
Missing Details
Some of this guide's details are missing. Help users by adding tools, difficulty, or time.
Introduction
Go to step 1 ↓The DJI Mini 3 is a lightweight, highly capable drone, but like any compact quadcopter, its arms are vulnerable to damage from crashes or wear over time. A cracked or loose arm can cause unstable flight or prevent the drone from taking off altogether. Fortunately, replacing a damaged arm is a straightforward repair that does not require replacing the entire aircraft.
This Fast Fix guide will walk you step-by-step through removing a damaged rear arm and installing a new one. The process involves opening the drone’s shell, disconnecting the arm’s wiring, and securely mounting the replacement component. With patience and a little finesse, you can get your Mini 3 back in the air in around an hour.
Tools
Didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
1 Guide Comment
Terrible guide. The first step doesn't mention the first two screws you need to remove.
If you do as the guide says, on step 1, you damage the shell forever.
The rest of the steps don't make sense either, this is useless.
Author should be banned.
