This teardown is not a repair guide. To repair your DJI Mini 3, use our service manual.
    1. DJI Mini 3 Chip ID, Drone Main Board Side A: step 1, image 1 of 2 DJI Mini 3 Chip ID, Drone Main Board Side A: step 1, image 2 of 2
      • Ambarella H22-A0-RH H22 quad-core video SoC
      • Kingston D1216ECMDXGME-U 256 MB DDR3L SDRAM memory
      • HDSC HC32F460JEUA 32-bit ARM Cortex-M4 microcontroller
      • Qualcomm SMB2352–207 dual-cell Li-ion battery charger
      • Monolithic Power Systems MP6507GQ stepper motor driver w/ MOSFETs
      • Silergy SY6280AAC power distribution switch
      • OmniVision WAS7222Q 480 Mbps DPDT analog switch
      Ask FixBot
    2. DJI Mini 3 Chip ID: step 2, image 1 of 1
      • Texas Instruments TLV75901P 1 A / adj. LDO regulator
      • OmniVision WL2836D12 300 mA / 1.2 V LDO regulator
      • OmniVision WL2836D18 300 mA / 1.8 V LDO regulator
      • OmniVision WL2848D18 300 mA / 1.8 V LDO regulator
      • OmniVision WL2836D25 300 mA / 2.5 V LDO regulator
      • Nexperia 74LVC2T45 dual supply translating transceiver
      • Nexperia 74LVC1G08 single 2-input AND gate
      Ask FixBot
    3. DJI Mini 3 Chip ID: step 3, image 1 of 1
      • Yangjie Electronic Technology YJQ1216A P-Channel MOSFET
      Ask FixBot
    4. DJI Mini 3 Chip ID, Drone Main Board Side A - Radio: step 4, image 1 of 1
      • Possibly Leadcore S1 RF transceiver
      • Kangxi Communication Technologies KCT8247HE-1 2.4 GHz WLAN front-end module
      • Kangxi Communication Technologies KCT8576N 5 GHz WLAN front-end module
      • Likely Maxscend MXDx213 low noise amplifier
      • Likely Maxscend DPDT RF switch
      • Likely Maxscend MXD8622E SPDT RF switch
      Ask FixBot
    5. DJI Mini 3 Chip ID, Drone Main Board Side B: step 5, image 1 of 2 DJI Mini 3 Chip ID, Drone Main Board Side B: step 5, image 2 of 2
      • NXP Semiconductor MIMXRT1064DVL6B i.MX single core application processor
      • Kioxia TC58NVG1S3HBAI6 256 MB NAND flash memory
      • Monolithic Power Systems MP6543HGL 3-phase power stage
      • Silicon Content Technology SCT2260A 6 A synchronous step-down DC-DC converter
      • Silicon Content Technology SCT2230 3 A synchronous step-down DC-DC converter
      • Monolithic Power Systems DC-DC Converter
      Ask FixBot
    6. DJI Mini 3 Chip ID: step 6, image 1 of 1
      • Possibly Linearin LTP3330 300 mA / 3.0 V LDO Regulator
      • OmniVision WL2836D33 300 mA / 3.3 V LDO regulator
      Ask FixBot
    7. DJI Mini 3 Chip ID, Drone Main Board Side B - Radio: step 7, image 1 of 1
      • Synaptics SYN43456PXKUBG single-chip 5G WiFi 802.11ac w/ Bluetooth 5 & FM receiver
      Ask FixBot
    8. DJI Mini 3 Chip ID, Distance Sensor Board Side A: step 8, image 1 of 2 DJI Mini 3 Chip ID, Distance Sensor Board Side A: step 8, image 2 of 2
      Ask FixBot
    9. DJI Mini 3 Chip ID, Distance Sensor Board Side B: step 9, image 1 of 2 DJI Mini 3 Chip ID, Distance Sensor Board Side B: step 9, image 2 of 2
      • Texas Instruments OPT3101 distance sensor analog front-end
      • SG Micro SGM2036-1.2 300 mA / 1.2 V LDO regulator
      • SG Micro SGM2036-1.8 300 mA / 1.8 V LDO regulator
      • SG Micro SGM2036-2.8 300 mA / 2.8 V LDO regulator
      Ask FixBot
    10. DJI Mini 3 Chip ID, GNSS Receiver Board Side A: step 10, image 1 of 2 DJI Mini 3 Chip ID, GNSS Receiver Board Side A: step 10, image 2 of 2
      • TDK-InvenSense ICM-40609-D 6-axis MEMS accelerometer & gyroscope
      • Goertek SPL06-001 pressure and temperature sensor
      Ask FixBot
    11. DJI Mini 3 Chip ID, GNSS Receiver Board Side B: step 11, image 1 of 2 DJI Mini 3 Chip ID, GNSS Receiver Board Side B: step 11, image 2 of 2
      • u-blox UBX-M10050-KB GNSS receiver
      • Maxscend MXDLN16TP GNSS low noise amplifier
      Ask FixBot
    12. DJI Mini 3 Chip ID, GNSS Receiver Board Side B - Filters: step 12, image 1 of 1
      Ask FixBot
    13. DJI Mini 3 Chip ID, Motor Controller Board Side A: step 13, image 1 of 2 DJI Mini 3 Chip ID, Motor Controller Board Side A: step 13, image 2 of 2
      • Texas Instruments DRV8328B 3-phase BLDC gate driver
      Ask FixBot
    14. DJI Mini 3 Chip ID, Motor Controller Board Side B: step 14, image 1 of 2 DJI Mini 3 Chip ID, Motor Controller Board Side B: step 14, image 2 of 2
      • Spintrol SPC1168APE48 32-bit ARM Cortex-M4 microcontroller
      • Vergiga VS3622DB 30 V dual N-channel MOSFET
      Ask FixBot
    15. DJI Mini 3 Chip ID, Sensor Flex Side A: step 15, image 1 of 2 DJI Mini 3 Chip ID, Sensor Flex Side A: step 15, image 2 of 2
      Ask FixBot
    16. DJI Mini 3 Chip ID, Battery Board Side A: step 16, image 1 of 2 DJI Mini 3 Chip ID, Battery Board Side A: step 16, image 2 of 2
      • Texas Instruments BQ9003 battery fuel gauge (likely)
      • Advanced Power Electronics Corp. AP3N1R8MT 30 V N-channel MOSFET
      Ask FixBot
    17. DJI Mini 3 Chip ID, Block Diagram: step 17, image 1 of 2 DJI Mini 3 Chip ID, Block Diagram: step 17, image 2 of 2
      • Predicted block diagram primarily based on available datasheets and observed implementation in product.
      Ask FixBot
CChin
7,169 Reputation
7 Guides authored
8 Guide Comments
Perfect sharing
BEKTAŞ KANTEMİR - Reply Share
It's great. Thank you. Did you also disassemble the dji mini4 or mini4 pro like that?
albert - Reply Share
Hi. Do you have high resolution on main board? I had my drone played submarine, so I had to clean the board. Few resistors located at the left of LEDs brushed out :(
Vitaliy K - Reply Share
If I was looking to reset the binding application but I'll be looking at the slc nand 256 flash memory all I need to do is short this chip out to flash it but I'll take out the recent bound
controller
Kiss Myass - Reply Share
sounds a little over optimistic - 99,9% chance the data is encrypted.
Paul, Ehrlich - Reply Share
Past 24 Hours: 8
Past 7 Days: 90
Past 30 Days: 392
All Time: 13,049
