DJI Mini 2 SE Battery Cover Replacement
Views: 3K
View statistics:
Past 24 Hours:
8
Past 7 Days:
38
Past 30 Days:
153
All Time:
3,024
Comments: 1
1 guide comment.
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Very easy
Community-Contributed Guide
Parts
Tools
    1. DJI Mini 2 SE Battery Cover Replacement, Doing this will void your warranty!: step 1, image 1 of 1
      • When opening the drone, this seal will break, DO THIS AT YOUR OWN RISK.
      Ask FixBot
    2. DJI Mini 2 SE Battery Cover Replacement, Remove The Battery: step 2, image 1 of 1
      • Simple Step.
      Ask FixBot
      • Ignore the low quality video
      Ask FixBot
    3. DJI Mini 2 SE Battery Cover Replacement, Prying Up: step 4, image 1 of 2 DJI Mini 2 SE Battery Cover Replacement, Prying Up: step 4, image 2 of 2
      • Insert an opening pick
      • Go around the drone. Carefully going around prying up.
      Ask FixBot
    4. DJI Mini 2 SE Battery Cover Replacement, Lift up the upper case: step 5, image 1 of 2 DJI Mini 2 SE Battery Cover Replacement, Lift up the upper case: step 5, image 2 of 2
      • Be careful not to touch any of the components.
      Ask FixBot
    5. DJI Mini 2 SE Battery Cover Replacement, Finding The Clips: step 6, image 1 of 3 DJI Mini 2 SE Battery Cover Replacement, Finding The Clips: step 6, image 2 of 3 DJI Mini 2 SE Battery Cover Replacement, Finding The Clips: step 6, image 3 of 3
      • Find the clips on the top cover.
      • Find the clips on the battery cover.
      Ask FixBot
    6. DJI Mini 2 SE Battery Cover Replacement, Clipping them together: step 7, image 1 of 1
      • It should look like this.
      Ask FixBot
    7. DJI Mini 2 SE Battery Cover Replacement, Putting the top cover back on: step 8, image 1 of 2 DJI Mini 2 SE Battery Cover Replacement, Putting the top cover back on: step 8, image 2 of 2
      • Push down on all of the clips around the drone with medium pressure.
      Ask FixBot
    8. DJI Mini 2 SE Battery Cover Replacement, Putting in the screws: step 9, image 1 of 1
      • Don't put them in too tight
      Ask FixBot
      • Put the battery in and test if it closes
      Ask FixBot
3 other people completed this guide.
Jordan
292 Reputation
1 Guide authored
1 Guide Comment
Thank you for making this guide! It really felt good to not go in completely blind.
Just so anyone else knows, this guide works for DJI Mini SE too!
Monika Mąka - Reply Share
Past 24 Hours: 8
Past 7 Days: 38
Past 30 Days: 153
All Time: 3,024
