DJI Mini 2 Propeller Blades Replacement
    1. DJI Mini 2 Propeller Blades Replacement, Propeller Blades: step 1, image 1 of 1
      • Open up the propeller arms to make it easier to access the propeller blades.
      • Then, place the drone on a flat surface.
      • There should be stickers on the device telling you how to unfold the propeller arms.
      Ask FixBot
    2. DJI Mini 2 Propeller Blades Replacement: step 2, image 1 of 2 DJI Mini 2 Propeller Blades Replacement: step 2, image 2 of 2
      • Remove the 7mm J000 head screw attaching the blade to the motor.
      • Some pressure may be needed to successfully unscrew the screw.
      • Remove the propeller blades.
      Ask FixBot
Attached Documents
Jacob Matos
1,613 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 55
All Time: 2,724
