DJI Mini 2 Drone Body Replacement
Views: 13K
View statistics:
Past 24 Hours:
8
Past 7 Days:
52
Past 30 Days:
271
All Time:
13,135
Comments: 14
10 comments on steps, 4 guide comments.
Go to guide comments
Completed: 13
13 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 - 20 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
We are defining the DJI Mini 2 drone body as the top and bottom plastic panels of the drone. These panels are the blockaded between the insides of the drone and the outside world.
The drone body stores the inner electronic parts of the drone like the GPS, the Main Board, and the wires the drone uses. Damage to the drone body can cause the drone to be unstable in flight. If the body of the drone is damaged they will need to be replaced.
Tools
    1. DJI Mini 2 Drone Body Replacement, Battery: step 1, image 1 of 2 DJI Mini 2 Drone Body Replacement, Battery: step 1, image 2 of 2
      • Face the DJI Mini 2 away from you so that you are looking at the charging ports.
      • Use your finger to open up the back panel.
      Ask FixBot
    2. DJI Mini 2 Drone Body Replacement: step 2, image 1 of 2 DJI Mini 2 Drone Body Replacement: step 2, image 2 of 2
      • Pinch the locking mechanism on the battery to release the lock.
      • Pull the battery straight out of the compartment.
      Ask FixBot
    1. DJI Mini 2 Drone Body Replacement, Drone Body: step 3, image 1 of 2 DJI Mini 2 Drone Body Replacement, Drone Body: step 3, image 2 of 2
      • Unfold the wings of the drone.
      • Place the drone upside down on a flat surface.
      • There should be stickers on the device telling you how to unfold the propeller arms.
      Ask FixBot
    2. DJI Mini 2 Drone Body Replacement: step 4, image 1 of 2 DJI Mini 2 Drone Body Replacement: step 4, image 2 of 2
      • Remove the four 5 mm J000 screws near each propeller arm.
      Ask FixBot
    3. DJI Mini 2 Drone Body Replacement: step 5, image 1 of 3 DJI Mini 2 Drone Body Replacement: step 5, image 2 of 3 DJI Mini 2 Drone Body Replacement: step 5, image 3 of 3
      • Flip the drone back over.
      • Use a combination of the opening tool and your fingers to pry open the top panel of the drone along the seams.
      Ask FixBot
    4. DJI Mini 2 Drone Body Replacement: step 6, image 1 of 2 DJI Mini 2 Drone Body Replacement: step 6, image 2 of 2
      • Remove the two 5 mm J000 screws located in the battery hatch and near the ports on the back of the drone.
      Ask FixBot
    5. DJI Mini 2 Drone Body Replacement: step 7, image 1 of 2 DJI Mini 2 Drone Body Replacement: step 7, image 2 of 2
      • Flip the drone over again.
      • Pry off the bottom panel of the drone using the opening tools and your fingers.
      Ask FixBot
13 other people completed this guide.
Jacob Matos
1,661 Reputation
4 Guides authored
4 Guide Comments
Where to buy a new drone body ?
Loïc Sarda - Reply Share
Same Q. Where to buy drone body? Please email me. Thanks
Ruud - Reply Share
Look for it on Google directly or in Amazon there are websites dedicated to sell the hole body parts
Pedro Burgos - Reply Share
Bonjour je suis novice ici j'aime beaucoup se que vous faites et je me demandais comment. M'inscrire ou vous rejoindre
Jojo Mignon - Reply Share
Past 24 Hours: 8
Past 7 Days: 52
Past 30 Days: 271
All Time: 13,135
