DJI Mavic Pro Propeller Replacement
Views: 7.6K
View statistics:
Past 24 Hours:
2
Past 7 Days:
28
Past 30 Days:
142
All Time:
7,649
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Very easy
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
Use this guide to replace a broken propeller of your DJI Mavic Pro Drone.
The propellers of a drone are very important. If the propellers are damaged, your flight may not be successful. Your propellers may need to be replaced if they crack or break when hit by an obstacle because broken propellers can affect the flight of the drone.
There are no tools required to replace the propellers of your drone, however you will need new propellers to replace the broken ones. Either you have bought the propellers separately or it has came with the drone.
Before beginning, make sure that your drone is powered off, do not replace the propellers when the drone is turned on.
Parts
    1. DJI Mavic Pro Propeller Replacement, Propellers: step 1, image 1 of 3 DJI Mavic Pro Propeller Replacement, Propellers: step 1, image 2 of 3 DJI Mavic Pro Propeller Replacement, Propellers: step 1, image 3 of 3
      • Unfold your Dji Mavic Pro Drone.
      Ask FixBot
    2. DJI Mavic Pro Propeller Replacement: step 2, image 1 of 3 DJI Mavic Pro Propeller Replacement: step 2, image 2 of 3 DJI Mavic Pro Propeller Replacement: step 2, image 3 of 3
      • Push down slightly on the propeller you want to remove.
      Ask FixBot
    3. DJI Mavic Pro Propeller Replacement: step 3, image 1 of 3 DJI Mavic Pro Propeller Replacement: step 3, image 2 of 3 DJI Mavic Pro Propeller Replacement: step 3, image 3 of 3
      • There are 2 types of propellers on a DJI Mavic Pro drone: 1 with a white circle outline (shown in the image) and 1 without.
      • If the propeller you want to remove has a white outline like shown in the image, then turn the propeller counterclockwise to unlock its position.
      Ask FixBot
    4. DJI Mavic Pro Propeller Replacement: step 4, image 1 of 3 DJI Mavic Pro Propeller Replacement: step 4, image 2 of 3 DJI Mavic Pro Propeller Replacement: step 4, image 3 of 3
      • If the propeller you want to remove DOES NOT have a white outline, then turn the propeller clockwise to unlock its position.
      Ask FixBot
    5. DJI Mavic Pro Propeller Replacement: step 5, image 1 of 3 DJI Mavic Pro Propeller Replacement: step 5, image 2 of 3 DJI Mavic Pro Propeller Replacement: step 5, image 3 of 3
      • Pull up the propeller to remove it.
      Ask FixBot
    6. DJI Mavic Pro Propeller Replacement: step 6, image 1 of 3 DJI Mavic Pro Propeller Replacement: step 6, image 2 of 3 DJI Mavic Pro Propeller Replacement: step 6, image 3 of 3
      • To replace the propellers, check to match the propellers with the arm of the drone.
      • The propeller with a white circle will have to be placed on the arm of the drone with a white outline and the propeller without the white circle will be placed on the arm of the drone without the white outline.
      Ask FixBot
    7. DJI Mavic Pro Propeller Replacement: step 7, image 1 of 3 DJI Mavic Pro Propeller Replacement: step 7, image 2 of 3 DJI Mavic Pro Propeller Replacement: step 7, image 3 of 3
      • Align the parts outlined with red with the holes on the arm of the drone outlined by the red.
      • Push the propeller down.
      Ask FixBot
    8. DJI Mavic Pro Propeller Replacement: step 8, image 1 of 2 DJI Mavic Pro Propeller Replacement: step 8, image 2 of 2
      • If the propeller has NO white mark (circle) then turn the propeller counterclockwise to lock its position.
      • If the propeller has a white mark (circle) then turn the propeller clockwise to lock its position.
      Ask FixBot
    9. DJI Mavic Pro Propeller Replacement: step 9, image 1 of 2 DJI Mavic Pro Propeller Replacement: step 9, image 2 of 2
      • Check to see if the propeller is properly locked into place by slightly pulling it up.
      • If it is locked, then you can safely fly your drone.
      Ask FixBot
Finish Line
2 other people completed this guide.
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 28
Past 30 Days: 142
All Time: 7,649
