Up to 20% off select tools
DJI Mavic Pro GPS Module Replacement
Views: 11K
View statistics:
Past 24 Hours:
4
Past 7 Days:
20
Past 30 Days:
104
All Time:
10,988
Comments: 22
22 comments on steps.
Completed: 8
8 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 minutes
Difficulty: Easy
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Tools
Introduction
Go to step 1 ↓
This set of instructions will walk you through the removal process of the DJI Mavic Pro GPS Module. You will first need to remove the battery and then the upper shell before you can get to the GPS Module. Be aware when going through the removal of the module that you may hear a popping sound; don't be alarmed as this is normal.
    1. DJI Mavic Pro GPS Module Replacement, Battery: step 1, image 1 of 3 DJI Mavic Pro GPS Module Replacement, Battery: step 1, image 2 of 3 DJI Mavic Pro GPS Module Replacement, Battery: step 1, image 3 of 3
      • Grab both sides of the battery.
      • Pinch the releasing buttons on both sides of the battery.
      • Lift the battery up and out.
      Ask FixBot
    1. DJI Mavic Pro GPS Module Replacement, Upper Shell: step 2, image 1 of 1
      • Remove the six 5mm 1.5 Hex screws by turning the screwdriver counterclockwise.
      Ask FixBot
    2. DJI Mavic Pro GPS Module Replacement: step 3, image 1 of 1
      • Flip the drone over so that the gimbal is facing up.
      • Remove the two 4mm 1.5 Hex screws near the gimbal case by turning the screwdriver counterclockwise.
      • Remove the two 5mm 1.5 Hex screws near the gimbal case by turning the screwdriver counterclockwise.
      Ask FixBot
    3. DJI Mavic Pro GPS Module Replacement: step 4, image 1 of 1
      Tool used on this step:
      Buy
      • Remove the two small panel pieces near the gimbal case with the tweezers.
      Ask FixBot
    4. DJI Mavic Pro GPS Module Replacement: step 5, image 1 of 1
      • Remove the two 5mm 1.5 Hex screws and two PH000 screws that are under the panel pieces by turning the respective screwdrivers counterclockwise.
      Ask FixBot
    5. DJI Mavic Pro GPS Module Replacement: step 6, image 1 of 1
      • Flip the drone back over so the upper shell is facing up.
      • Pry off the upper shell with a nylon spudger.
      • Be careful when prying with the spudger because you could damage the upper shell's plastic tabs.
      Ask FixBot
    6. DJI Mavic Pro GPS Module Replacement: step 7, image 1 of 1
      • Remove the white connector at the back of the flight controller board by gently pulling at the base.
      Ask FixBot
    1. DJI Mavic Pro GPS Module Replacement, GPS Module: step 8, image 1 of 1
      • Flip the upper shell over so the metallic plate is facing up.
      • Remove the two 5mm JIS #00 screws from the metallic plate by turning the screwdriver counterclockwise.
      • If the JIS #00 screwdriver is too small, you may need to use a JIS #0 screwdriver.
      Ask FixBot
    2. DJI Mavic Pro GPS Module Replacement: step 9, image 1 of 1
      • Pry the metallic plate up from the upper shell by using a nylon spudger.
      • Remove the metallic plate from the upper shell by lifting the plate up and out.
      • You may hear a popping sound when prying the metallic plate, but no damage will occur.
      Ask FixBot
    3. DJI Mavic Pro GPS Module Replacement: step 10, image 1 of 1
      Buy
      • Use tweezers to remove the GPS Module from the upper shell.
      Ask FixBot
8 other people completed this guide.
Author
with
Kyle Kelser
650 Reputation
2 Guides authored
Cal Poly, Team S17-G3, White Fall 2018 Member of Cal Poly, Team S17-G3, White Fall 2018
CPSU-WHITE-F18S17G3
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 20
Past 30 Days: 104
All Time: 10,988
