Up to 20% off select tools
DJI Mavic Pro Front Vision Replacement
Views: 9.1K
View statistics:
Past 24 Hours:
3
Past 7 Days:
21
Past 30 Days:
138
All Time:
9,080
Comments: 40
36 comments on steps, 4 guide comments.
Go to guide comments
Completed: 8
8 people have marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 25 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
This guide is for removing the DJI Mavic Pro Front Vision. To get to the front vision, you will need to remove the battery, upper shell, and gimbal first. In order to remove the gimbal in step 8, you will need to scrape some plastic adhesive off your device. Tweezers and three different sized screwdrivers are required for this guide.
    1. DJI Mavic Pro Front Vision Replacement, Battery: step 1, image 1 of 3 DJI Mavic Pro Front Vision Replacement, Battery: step 1, image 2 of 3 DJI Mavic Pro Front Vision Replacement, Battery: step 1, image 3 of 3
      • Grab both sides of the battery.
      • Pinch the releasing buttons on both sides of the battery.
      • Lift the battery up and out.
      Ask FixBot
    1. DJI Mavic Pro Front Vision Replacement, Upper Shell: step 2, image 1 of 1
      • Remove the six 5mm 1.5 Hex screws by turning the screwdriver counterclockwise.
      Ask FixBot
    2. DJI Mavic Pro Front Vision Replacement: step 3, image 1 of 1
      • Flip the drone over so that the gimbal is facing up.
      • Remove the two 4mm 1.5 Hex screws near the gimbal case by turning the screwdriver counterclockwise.
      • Remove the two 5mm 1.5 Hex screws near the gimbal case by turning the screwdriver counterclockwise.
      Ask FixBot
    3. DJI Mavic Pro Front Vision Replacement: step 4, image 1 of 1
      Tool used on this step:
      Buy
      • Remove the two small panel pieces near the gimbal case with the tweezers.
      Ask FixBot
    4. DJI Mavic Pro Front Vision Replacement: step 5, image 1 of 1
      • Remove the two 5mm 1.5 Hex screws and two PH000 screws that are under the panel pieces by turning the respective screwdrivers counterclockwise.
      Ask FixBot
    5. DJI Mavic Pro Front Vision Replacement: step 6, image 1 of 1
      • Flip the drone back over so the upper shell is facing up.
      • Pry off the upper shell with a nylon spudger.
      • Be careful when prying with the spudger because you could damage the upper shell's plastic tabs.
      Ask FixBot
    6. DJI Mavic Pro Front Vision Replacement: step 7, image 1 of 1
      • Remove the white connector at the back of the flight controller board by gently pulling at the base.
      Ask FixBot
    1. DJI Mavic Pro Front Vision Replacement, Gimbal/Camera: step 8, image 1 of 1
      • Remove the one 5mm JIS #0 screw from the small micro controller board at the front of the DJI Mavic Pro by turning counterclockwise.
      Ask FixBot
    2. DJI Mavic Pro Front Vision Replacement: step 9, image 1 of 1
      Buy
      • Pull the cord and micro controller board away from the front of the DJI Mavic Pro using tweezers.
      Ask FixBot
    3. DJI Mavic Pro Front Vision Replacement: step 10, image 1 of 2 DJI Mavic Pro Front Vision Replacement: step 10, image 2 of 2
      • Expose the two small ZIF connectors near the front of the board by removing the plastic coverings.
      • Then, remove the two ZIF connectors under the coverings using a nylon spudger.
      Ask FixBot
    4. DJI Mavic Pro Front Vision Replacement: step 11, image 1 of 1
      • Remove two 6mm JIS #00 screws from the plastic board cover at the front of the DJI Mavic Pro.
      Ask FixBot
    5. DJI Mavic Pro Front Vision Replacement: step 12, image 1 of 2 DJI Mavic Pro Front Vision Replacement: step 12, image 2 of 2
      • Flip the DJI Mavic Pro over.
      • Gently press the latch for the Gimbal cover.
      • Pull the cover off.
      Ask FixBot
    6. DJI Mavic Pro Front Vision Replacement: step 13, image 1 of 2 DJI Mavic Pro Front Vision Replacement: step 13, image 2 of 2
      • Flip the DJI Mavic Pro back over, with its top side facing up.
      • Remove the two ZIF connectors located behind the plastic covers by using a nylon spudger.
      Ask FixBot
    7. DJI Mavic Pro Front Vision Replacement: step 14, image 1 of 1
      • Gently remove the power cable connector located to the left, behind the gimbal board, by pulling up on the white base.
      Ask FixBot
    8. DJI Mavic Pro Front Vision Replacement: step 15, image 1 of 1
      • Scrape away the plastic adhesive covering the two 5mm JIS #000 screws connected to the gimbal board.
      • Remove the two 5mm JIS #000 screws from the gimbal board by turning the screwdriver counterclockwise.
      Ask FixBot
    9. DJI Mavic Pro Front Vision Replacement: step 16, image 1 of 1
      • Remove the two 7mm JIS #00 screws at the very front of the DJI Mavic Pro by turning the screwdriver counterclockwise.
      • Careful when removing these screws the camera or whatever remains of your camera assembly may drop
      Ask FixBot
    10. DJI Mavic Pro Front Vision Replacement: step 17, image 1 of 2 DJI Mavic Pro Front Vision Replacement: step 17, image 2 of 2
      • Flip the DJI Mavic Pro over, with the camera facing you.
      • Gently pull the gimbal/camera assembly up and out.
      Ask FixBot
    1. DJI Mavic Pro Front Vision Replacement, Front Vision: step 18, image 1 of 1
      • Remove the two 6mm JIS #0 screws by turning counterclockwise.
      Ask FixBot
    2. DJI Mavic Pro Front Vision Replacement: step 19, image 1 of 1
      • Remove the front vision piece by pulling the piece up and away from the drone body.
      Ask FixBot
8 other people completed this guide.
Author
with
Kyle Kelser
650 Reputation
2 Guides authored
Cal Poly, Team S17-G3, White Fall 2018 Member of Cal Poly, Team S17-G3, White Fall 2018
CPSU-WHITE-F18S17G3
4 Members
72 Guides authored
4 Guide Comments
What error codes did you get before having to replace this front cameras?
Daniel Rubio Rocamora - Reply Share
la nacelle de mon drone mavic pro ne fais aucun mouvement quand je l'allume s'il vous plaît quel pourrait être le problème ?
Picharkayo@gmail.com
Pichar Kayo - Reply Share
it's most likely the ribbon cable 9-dollar fix from Amazon. that would be my first guess
J. Brown - Reply Share
I have error of forward motion isn’t recognizing how can I fix it please help
Aoldmilkman1 - Reply Share
Past 24 Hours: 3
Past 7 Days: 21
Past 30 Days: 138
All Time: 9,080
