DJI Mavic Mini Propellers Replacement
    1. DJI Mavic Mini Propellers Replacement, Propellers: step 1, image 1 of 3 DJI Mavic Mini Propellers Replacement, Propellers: step 1, image 2 of 3 DJI Mavic Mini Propellers Replacement, Propellers: step 1, image 3 of 3
      • Place the DJI Mavic Mini on a flat surface with the props oriented upwards.
      • For ease of access place the prop arms in the "open" position.
      Ask FixBot
    2. DJI Mavic Mini Propellers Replacement: step 2, image 1 of 3 DJI Mavic Mini Propellers Replacement: step 2, image 2 of 3 DJI Mavic Mini Propellers Replacement: step 2, image 3 of 3
      • Remove the 2.4 mm J000 screw from the damaged propeller.
      • When removing the screws, you may need to apply some pressure to the swivel mount that holds the propellers.
      • Remove the damaged propellers.
      Ask FixBot
    3. DJI Mavic Mini Propellers Replacement: step 3, image 1 of 2 DJI Mavic Mini Propellers Replacement: step 3, image 2 of 2
      • Keep the 2.4 mm J000 screw from the damaged propeller to use again when fastening on the replacement.
      • While one or both propellers are removed for replacement, it is recommended that you inspect the exposed swivel mount for any debris which may impact drone performance.
      • Additionally, when fastening the replacement propeller make sure that the screw is inserted into the interior hole on the swivel mount.
      Ask FixBot
Chase Smith
147 Reputation
1 Guide authored
Clemson, Team 1-2, Hunter Spring 2022 Member of Clemson, Team 1-2, Hunter Spring 2022
CLEM-HUNTER-S22S1G2
5 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 46
All Time: 1,666
