Up to 20% off select tools
DJI Mavic Mini Disassembly
Views: 14K
View statistics:
Past 24 Hours:
10
Past 7 Days:
55
Past 30 Days:
228
All Time:
14,290
Comments: 4
4 guide comments.
Go to guide comments
Completed: 7
7 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 40 minutes
Difficulty: Moderate
Community-Contributed Guide
Needs Transcription
This guide is in video form only. Help make it more accessible by transcribing each action of the procedure into a separate step and adding photos.
Introduction
Disassembling the Mavic Mini drone to replace any of the defective parts.
After replacing the motherboard or gimbal camera, you need to calibrate the drone. How to calibrate the DJI Mavic Mini, watch this manual https://youtu.be/mu03HWXplM4
Video Instructions
7 other people completed this guide.
Author
with
Arty
34,703 Reputation
110 Guides authored
4 Guide Comments
Hey, wanted to say thanks for this video. Super helpful. I crashed the eff out of my Mavic Mini and was getting an error 30045, "Gyroscope initialization failed. Restart aircraft." Looks like my ribbon cable that connects the gyroscope chip module to the main board somehow got ripped (or possibly melted through, I was flying in a rather warm climate.) Of course, it's the longest and most complex cable in the drone, so it'll be a job to get it replaced. I'm ordering a new one and going to see if I can switch it out successfully. Thank you!!
Chris Zirker - Reply Share
Well you didn’t remove the arms, so not a complete breakdown. I can’t get the pins for the arms back in as the spring loading turns the middle section so that when you screw it in they don’t spring open.
kelly - Reply Share
Thank you for the information. I am able to put off buying a new drone for the time... (Those pesky trees and gravity)
Humanoid Planetearth - Reply Share
Excellent teardown and build! Very detailed.
And yes - gravity + trees + drone is pesky indeed :)
Knyte - Reply Share
Past 24 Hours: 10
Past 7 Days: 55
Past 30 Days: 228
All Time: 14,290
