DJI Mavic Mini Battery Replacement
    1. DJI Mavic Mini Battery Replacement, Battery: step 1, image 1 of 2 DJI Mavic Mini Battery Replacement, Battery: step 1, image 2 of 2
      • Orient the DJI Mavic Mini so that the camera faces away.
      • Use your finger to depress the lip on the panel until the lid becomes ajar.
      • Flip the panel up to expose the battery module.
      Ask FixBot
    2. DJI Mavic Mini Battery Replacement: step 2, image 1 of 2 DJI Mavic Mini Battery Replacement: step 2, image 2 of 2
      • Depress the locking mechanism on the battery module to release the lock.
      • Pull the battery straight out of the casing.
      Ask FixBot
    3. DJI Mavic Mini Battery Replacement: step 3, image 1 of 2 DJI Mavic Mini Battery Replacement: step 3, image 2 of 2
      • Check the battery pins on the DJI Drone for corrosion or warping. If either of these conditions are present, replacing the battery module may not help resolve the issue at hand.
      • Check the pin receptacles on the battery module for blockages.
      • Insert a new battery into the casing. Ensure that all connections are clean, unobstructed, and straight.
      Ask FixBot
Is your DJI Mavic Mini experiencing trouble with positioning, stability, or returning to home? Many of these problems an be due to weak signals or a faulty GPS. In this set of instructions, we will detail the removal process, inspection, and replacement of the DJI Mavic Mini GPS Module.
Cooper Schroeder
284 Reputation
2 Guides authored
Clemson, Team 1-2, Hunter Spring 2022 Member of Clemson, Team 1-2, Hunter Spring 2022
CLEM-HUNTER-S22S1G2
5 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 20
Past 30 Days: 81
All Time: 2,880
