Up to 20% off select tools
DJI FPV Water Damage Recovery Guide
View statistics:
Past 24 Hours:
7
Past 7 Days:
22
Past 30 Days:
86
All Time:
652
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 55 minutes
Difficulty: Moderate
Community-Contributed Guide
Needs Transcription
This guide is in video form only. Help make it more accessible by transcribing each action of the procedure into a separate step and adding photos.
Introduction
Did your DJI FPV drone crash into water? Don’t panic — this video guide walks you through the full recovery process to help you safely restore your drone after a freshwater or saltwater incident. Whether your drone took a quick dip or was submerged for several minutes, this step-by-step method gives you the best chance of saving it.
This guide applies to any DJI drone model, including DJI FPV, Avata, Air series, Mini series, Mavic, Inspire, and more. You’ll learn how to clean the internal components using distilled water and isopropyl alcohol, how to dry everything properly, and what signs of damage to look out for before powering it back on.
👍 No special tools or advanced skills required — just patience, care, and the right technique.
🔧 Key Takeaways:
  • Safe cleaning and drying steps for DJI FPV and other models
  • How to remove salt and minerals from electronics
  • Tips to prevent corrosion and future issues
  • When it's safe to test your drone again
  • What to do if the drone won't turn on or has connection issues
⚠️ Note: Attempting self-repair may void your warranty. If your DJI FPV drone is still under warranty or covered by DJI Care Refresh, consider contacting official DJI support first.
Video Instructions
Author
with
Arty
34,705 Reputation
110 Guides authored
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 22
Past 30 Days: 86
All Time: 652
