Up to 20% off select tools
DDX/ Copperhead Hotend Installation
View statistics:
Past 24 Hours:
3
Past 7 Days:
10
Past 30 Days:
62
All Time:
567
Comments: 2
2 guide comments.
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Community-Contributed Guide
Introduction
Go to step 1 ↓
Credit for images and text goes to our partner, Bondtech AB
    1. DDX/ Copperhead Hotend Installation, Prepare Copperhead™ Adapter: step 1, image 1 of 3 DDX/ Copperhead Hotend Installation, Prepare Copperhead™ Adapter: step 1, image 2 of 3 DDX/ Copperhead Hotend Installation, Prepare Copperhead™ Adapter: step 1, image 3 of 3
      • Use 2x 2.5x6mm screws supplied with the Copperhead™ hotend.
      • Insert them in the mounting holes.
      Ask FixBot
    2. DDX/ Copperhead Hotend Installation, Attach Adapter To Hotend: step 2, image 1 of 2 DDX/ Copperhead Hotend Installation, Attach Adapter To Hotend: step 2, image 2 of 2
      • Attach Adapter and hotend.
      • New lineNotice the orientation of the Adapter and Hot Block.
      • These indented marks should be oriented towards the front of the DDX.
      • The fixation screws that attach the DDX to the carriage plate will enter through them.
      Ask FixBot
    3. DDX/ Copperhead Hotend Installation, Prepare PTFE Tube: step 3, image 1 of 3 DDX/ Copperhead Hotend Installation, Prepare PTFE Tube: step 3, image 2 of 3 DDX/ Copperhead Hotend Installation, Prepare PTFE Tube: step 3, image 3 of 3
      • Insert the Capricorn tube inside the Adapter and hotend.
      • Push hard until it hits the bottom.
      • Download the PTFE cutting fixture
      Ask FixBot
    4. DDX/ Copperhead Hotend Installation, Cut PTFE Tube To Spec: step 4, image 1 of 3 DDX/ Copperhead Hotend Installation, Cut PTFE Tube To Spec: step 4, image 2 of 3 DDX/ Copperhead Hotend Installation, Cut PTFE Tube To Spec: step 4, image 3 of 3
      • Insert the Capricorn tube in the cutting fixture
      • Drive it until it fits the Adapter
      • Pressing all together use the hobby knife to cut the tube straight.
      • At the end, the Capricorn should stand out about 5mm.
      Ask FixBot
    5. DDX/ Copperhead Hotend Installation, Insert Copperhead™ Into DDX: step 5, image 1 of 3 DDX/ Copperhead Hotend Installation, Insert Copperhead™ Into DDX: step 5, image 2 of 3 DDX/ Copperhead Hotend Installation, Insert Copperhead™ Into DDX: step 5, image 3 of 3
      • Spread the housing apart from 2 to 3mm
      • Insert the Copperhead™ in at an angle.
      • Push it until the mounting holes align.
      Ask FixBot
    6. DDX/ Copperhead Hotend Installation, Close DDX 1/2: step 6, image 1 of 3 DDX/ Copperhead Hotend Installation, Close DDX 1/2: step 6, image 2 of 3 DDX/ Copperhead Hotend Installation, Close DDX 1/2: step 6, image 3 of 3
      • If when clamping the DDX the gears collide:
      • Release the thumbscrew.
      • Open the hinge.
      • Clamp both halves while rotating the main gear back and forth.
      Ask FixBot
    7. DDX/ Copperhead Hotend Installation, Close DDX 2/2: step 7, image 1 of 3 DDX/ Copperhead Hotend Installation, Close DDX 2/2: step 7, image 2 of 3 DDX/ Copperhead Hotend Installation, Close DDX 2/2: step 7, image 3 of 3
      • When the DDX closes down verify the mounting holes alignment.
      • Screw the back screws to close it.
      Ask FixBot
Author
with
Tiny Machines 3D
3,089 Reputation
14 Guides authored
Tiny Machines 3D Member of Tiny Machines 3D
Community
5 Members
372 Guides authored
2 Guide Comments
where do i get the cutting fixture
Sarbartha Sengupta - Reply Share
Thanks for your questions. We’ve added a link to step 3.
Tiny Machines 3D - Reply Share
Past 24 Hours: 3
Past 7 Days: 10
Past 30 Days: 62
All Time: 567
