DCC-3200 Faulty Power Cord Replacement
Views: 3.1K
View statistics:
Past 24 Hours:
2
Past 7 Days:
19
Past 30 Days:
81
All Time:
3,056
Comments: 2
2 comments on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
Have you ever gone to plug in your Cuisinart DCC-3200 coffee maker, and you realize no matter what you do it just won't turn on? You try to plug it into different outlets and no matter where you go you can't seem to get it to work. Now, before you throw out the whole machine and go scrolling online to buy a new one why not try to fix it yourself? This guide will go over the step-by-step replacement process of a faulty power cord on a Cuisinart DCC-3200 coffee maker. All recommended tools for this repair are listed at the beginning of this guide.
The power cord on your Cuisinart DCC-3200 coffee maker is what connects it to an electrical utility or power supply. Without it your application will not be able to work.
Step 7 requires you to use a Wire Stripper to twist a wire. Depending on the state of the wire it may require you to Solder it back on with a soldering iron.
Tools
    1. DCC-3200 Faulty Power Cord Replacement, Faulty Power Cord: step 1, image 1 of 1
      • First, please be sure that the device is unplugged and that there is no water in the reservoir.
      • Check the power cord for frays or cracks.
      Ask FixBot
    2. DCC-3200 Faulty Power Cord Replacement: step 2, image 1 of 1
      • If the cord appears fine, please flip the device upside-down and unscrew the 4 screws on the bottom.
      Ask FixBot
    3. DCC-3200 Faulty Power Cord Replacement: step 3, image 1 of 1
      • Remove the bottom panel and unclip the power cord from the panel.
      Ask FixBot
    4. DCC-3200 Faulty Power Cord Replacement: step 4, image 1 of 1
      • With the front facing towards you upside down, to the top left of the circular hotplate is a beige circuit board with two screws on either side holding it in. Please unscrew them.
      Ask FixBot
    5. DCC-3200 Faulty Power Cord Replacement: step 5, image 1 of 1
      • Carefully remove the circuit board and unplug the gray ribbon wire that is plugged into it.
      Ask FixBot
    6. DCC-3200 Faulty Power Cord Replacement: step 6, image 1 of 1
      • Check to see if the power cord is connected properly to the circuit board.
      Ask FixBot
    7. DCC-3200 Faulty Power Cord Replacement: step 7, image 1 of 1
      • Strip the wire and twist with the other or solder it back on.
      Ask FixBot
Hamad Khan
385 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 19
Past 30 Days: 81
All Time: 3,056
