DBPOWER T20 Speaker Replacement
    1. DBPOWER T20 Speaker Replacement, DBPOWER T20 Disassembly: step 1, image 1 of 1
      • Flip the device and lay flat.
      Ask FixBot
    2. DBPOWER T20 Speaker Replacement: step 2, image 1 of 1
      • Remove the four (9 mm) screws with a PH2 screwdriver.
      • Remove the two (7 mm) located with a PH2 screwdriver.
      Ask FixBot
    3. DBPOWER T20 Speaker Replacement: step 3, image 1 of 3 DBPOWER T20 Speaker Replacement: step 3, image 2 of 3 DBPOWER T20 Speaker Replacement: step 3, image 3 of 3
      • Flip the device over and pry the top off with a plastic opening tool.
      Ask FixBot
    4. DBPOWER T20 Speaker Replacement: step 4, image 1 of 1
      • Remove the ribbon cable connecting the motherboard to the button control board by gently pulling it from its connector.
      Ask FixBot
    5. DBPOWER T20 Speaker Replacement: step 5, image 1 of 2 DBPOWER T20 Speaker Replacement: step 5, image 2 of 2
      • Remove four (6 mm) screws connecting the motherboard using a J0 screwdriver.
      Ask FixBot
    6. DBPOWER T20 Speaker Replacement: step 6, image 1 of 3 DBPOWER T20 Speaker Replacement: step 6, image 2 of 3 DBPOWER T20 Speaker Replacement: step 6, image 3 of 3
      • Remove the two cables connected to the motherboard: black power cable and the red/black fan cable.
      • the black cable requires more force to remove than the other cables.
      Ask FixBot
    7. DBPOWER T20 Speaker Replacement: step 7, image 1 of 2 DBPOWER T20 Speaker Replacement: step 7, image 2 of 2
      • Lift the black latch on the ZIF connector and remove the ribbon cable that attaches the digitizer to the motherboard.
      Ask FixBot
    8. DBPOWER T20 Speaker Replacement: step 8, image 1 of 1
      • Raise motherboard by lifting sideways and then up to avoid the ports.
      Ask FixBot
    9. DBPOWER T20 Speaker Replacement: step 9, image 1 of 2 DBPOWER T20 Speaker Replacement: step 9, image 2 of 2
      • Remove wires attaching the piezoelectric speakers to the motherboard.
      Ask FixBot
    10. DBPOWER T20 Speaker Replacement: step 10, image 1 of 2 DBPOWER T20 Speaker Replacement: step 10, image 2 of 2
      • Remove the five screws securing the black plastic cover with a J0 screwdriver.
      • Lift up and out to remove.
      Ask FixBot
    1. DBPOWER T20 Speaker Replacement, Speaker: step 11, image 1 of 2 DBPOWER T20 Speaker Replacement, Speaker: step 11, image 2 of 2
      • Remove the two (3 mm) screws connecting the bracket down and pull out the reflector, using a J0 Philips Head Screwdriver.
      Ask FixBot
    2. DBPOWER T20 Speaker Replacement: step 12, image 1 of 3 DBPOWER T20 Speaker Replacement: step 12, image 2 of 3 DBPOWER T20 Speaker Replacement: step 12, image 3 of 3
      • Slide the mirror straight up to remove.
      Ask FixBot
    3. DBPOWER T20 Speaker Replacement: step 13, image 1 of 3 DBPOWER T20 Speaker Replacement: step 13, image 2 of 3 DBPOWER T20 Speaker Replacement: step 13, image 3 of 3
      • Slide out the power source and disconnect its cables from the power jack and the light.
      Ask FixBot
    4. DBPOWER T20 Speaker Replacement: step 14, image 1 of 3 DBPOWER T20 Speaker Replacement: step 14, image 2 of 3 DBPOWER T20 Speaker Replacement: step 14, image 3 of 3
      • Remove the screws holding down the first speaker with a J0 screwdriver.
      • Remove the screws holding down the second speaker down.
      Ask FixBot
2 other people completed this guide.
Ryan Goldin
248 Reputation
1 Guide authored
USF Tampa, Team S16-G2, Boczar Spring 2018 Member of USF Tampa, Team S16-G2, Boczar Spring 2018
USFT-BOCZAR-S18S16G2
5 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 27
All Time: 808
