DBPOWER T20 Lens Replacement
Views: 3.2K
View statistics:
Past 24 Hours:
2
Past 7 Days:
19
Past 30 Days:
79
All Time:
3,190
Comments: 9
6 comments on steps, 3 guide comments.
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 20 minutes
Difficulty: Moderate
Better Introduction
Improve this guide by completing or revising its introduction.
Introduction
Go to step 1 ↓
You will not be able to access the lens without following these steps. Removing the lens does not take a lot of force since it is on a hinge and should lift out easily. However, none of the items you come in contact with leading up to the lens removal are sturdy so don't be afraid to use some force.
Tools
    1. DBPOWER T20 Lens Replacement, DBPOWER T20 Disassembly: step 1, image 1 of 1
      • Flip the device and lay flat.
      Ask FixBot
    2. DBPOWER T20 Lens Replacement: step 2, image 1 of 1
      • Remove the four (9 mm) screws with a PH2 screwdriver.
      • Remove the two (7 mm) located with a PH2 screwdriver.
      Ask FixBot
    3. DBPOWER T20 Lens Replacement: step 3, image 1 of 3 DBPOWER T20 Lens Replacement: step 3, image 2 of 3 DBPOWER T20 Lens Replacement: step 3, image 3 of 3
      • Flip the device over and pry the top off with a plastic opening tool.
      Ask FixBot
    4. DBPOWER T20 Lens Replacement: step 4, image 1 of 1
      • Remove the ribbon cable connecting the motherboard to the button control board by gently pulling it from its connector.
      Ask FixBot
    5. DBPOWER T20 Lens Replacement: step 5, image 1 of 2 DBPOWER T20 Lens Replacement: step 5, image 2 of 2
      • Remove four (6 mm) screws connecting the motherboard using a J0 screwdriver.
      Ask FixBot
    6. DBPOWER T20 Lens Replacement: step 6, image 1 of 3 DBPOWER T20 Lens Replacement: step 6, image 2 of 3 DBPOWER T20 Lens Replacement: step 6, image 3 of 3
      • Remove the two cables connected to the motherboard: black power cable and the red/black fan cable.
      • the black cable requires more force to remove than the other cables.
      Ask FixBot
    7. DBPOWER T20 Lens Replacement: step 7, image 1 of 2 DBPOWER T20 Lens Replacement: step 7, image 2 of 2
      • Lift the black latch on the ZIF connector and remove the ribbon cable that attaches the digitizer to the motherboard.
      Ask FixBot
    8. DBPOWER T20 Lens Replacement: step 8, image 1 of 1
      • Raise motherboard by lifting sideways and then up to avoid the ports.
      Ask FixBot
    9. DBPOWER T20 Lens Replacement: step 9, image 1 of 2 DBPOWER T20 Lens Replacement: step 9, image 2 of 2
      • Remove wires attaching the piezoelectric speakers to the motherboard.
      Ask FixBot
    10. DBPOWER T20 Lens Replacement: step 10, image 1 of 2 DBPOWER T20 Lens Replacement: step 10, image 2 of 2
      • Remove the five screws securing the black plastic cover with a J0 screwdriver.
      • Lift up and out to remove.
      Ask FixBot
    1. DBPOWER T20 Lens Replacement, Lens: step 11, image 1 of 1
      • The lamp does not need to be removed for this step to be preformed.
      Ask FixBot
    2. DBPOWER T20 Lens Replacement: step 12, image 1 of 1
      • Detach the keystone adjuster from the lens housing.
      • Lens is on a hinge so it should lift off easily, if it doesn't, adjust by swaying it forward or backward.
      Ask FixBot
    3. DBPOWER T20 Lens Replacement: step 13, image 1 of 1
      • Remove the rubber foot and warranty sticker found underneath the device.
      Ask FixBot
    4. DBPOWER T20 Lens Replacement: step 14, image 1 of 2 DBPOWER T20 Lens Replacement: step 14, image 2 of 2
      • Remove the two screws on the bottom of the device with a J0 screwdriver.
      Ask FixBot
    5. DBPOWER T20 Lens Replacement: step 15, image 1 of 1
      • Remove the focus-adjustment ring from the lens housing.
      Ask FixBot
4 other people completed this guide.
Andrea Espinosa
521 Reputation
3 Guides authored
USF Tampa, Team S16-G2, Boczar Spring 2018 Member of USF Tampa, Team S16-G2, Boczar Spring 2018
USFT-BOCZAR-S18S16G2
5 Members
60 Guides authored
3 Guide Comments
How does the lens parts go together?
Lay - Reply Share
I need to know the same
Tremaine Mullins - Reply Share
Trying to put my lens back how to install
David Williams - Reply Share
Past 24 Hours: 2
Past 7 Days: 19
Past 30 Days: 79
All Time: 3,190
