Up to 20% off select tools
DBPOWER T20 Lamp Replacement
Views: 5K
View statistics:
Past 24 Hours:
6
Past 7 Days:
16
Past 30 Days:
82
All Time:
4,979
Comments: 11
5 comments on steps, 6 guide comments.
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 25 minutes
Difficulty: Moderate
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
Introduction
Go to step 1 ↓
Simply pull the lamp out once you remove the screws. This should not require much force so if the lamp is not coming out, make sure you took out all the screws in the steps leading up to the removal.
    1. DBPOWER T20 Lamp Replacement, DBPOWER T20 Disassembly: step 1, image 1 of 1
      • Flip the device and lay flat.
      Ask FixBot
    2. DBPOWER T20 Lamp Replacement: step 2, image 1 of 1
      • Remove the four (9 mm) screws with a PH2 screwdriver.
      • Remove the two (7 mm) located with a PH2 screwdriver.
      Ask FixBot
    3. DBPOWER T20 Lamp Replacement: step 3, image 1 of 3 DBPOWER T20 Lamp Replacement: step 3, image 2 of 3 DBPOWER T20 Lamp Replacement: step 3, image 3 of 3
      • Flip the device over and pry the top off with a plastic opening tool.
      Ask FixBot
    4. DBPOWER T20 Lamp Replacement: step 4, image 1 of 1
      • Remove the ribbon cable connecting the motherboard to the button control board by gently pulling it from its connector.
      Ask FixBot
    5. DBPOWER T20 Lamp Replacement: step 5, image 1 of 2 DBPOWER T20 Lamp Replacement: step 5, image 2 of 2
      • Remove four (6 mm) screws connecting the motherboard using a J0 screwdriver.
      Ask FixBot
    6. DBPOWER T20 Lamp Replacement: step 6, image 1 of 3 DBPOWER T20 Lamp Replacement: step 6, image 2 of 3 DBPOWER T20 Lamp Replacement: step 6, image 3 of 3
      • Remove the two cables connected to the motherboard: black power cable and the red/black fan cable.
      • the black cable requires more force to remove than the other cables.
      Ask FixBot
    7. DBPOWER T20 Lamp Replacement: step 7, image 1 of 2 DBPOWER T20 Lamp Replacement: step 7, image 2 of 2
      • Lift the black latch on the ZIF connector and remove the ribbon cable that attaches the digitizer to the motherboard.
      Ask FixBot
    8. DBPOWER T20 Lamp Replacement: step 8, image 1 of 1
      • Raise motherboard by lifting sideways and then up to avoid the ports.
      Ask FixBot
    9. DBPOWER T20 Lamp Replacement: step 9, image 1 of 2 DBPOWER T20 Lamp Replacement: step 9, image 2 of 2
      • Remove wires attaching the piezoelectric speakers to the motherboard.
      Ask FixBot
    10. DBPOWER T20 Lamp Replacement: step 10, image 1 of 2 DBPOWER T20 Lamp Replacement: step 10, image 2 of 2
      • Remove the five screws securing the black plastic cover with a J0 screwdriver.
      • Lift up and out to remove.
      Ask FixBot
    1. DBPOWER T20 Lamp Replacement, Lamp: step 11, image 1 of 1
      • Remove the two screws attached to the lamp with a J0 screwdriver.
      Ask FixBot
    2. DBPOWER T20 Lamp Replacement: step 12, image 1 of 1
      • Lift upwards to remove the lamp.
      Ask FixBot
4 other people completed this guide.
Author
with
Andrea Espinosa
521 Reputation
3 Guides authored
USF Tampa, Team S16-G2, Boczar Spring 2018 Member of USF Tampa, Team S16-G2, Boczar Spring 2018
USFT-BOCZAR-S18S16G2
5 Members
60 Guides authored
6 Guide Comments
where can I get the replacement lamp?
David Rug - Reply Share
The part that is being removed is NOT the LED lamp. My interest is replacing the actual LED lamp that sits behind the plastic part that is being removed. My projector image started to have a tan cast to it near the top left portion of the screen due to overheating. I am just assuming that it is the actual LED that is overheating and need replacing. The article is very good otherwise. Please add where replacement parts can be obtained.
m patn - Reply Share
Thank you very much, I appreciate the ability to get a look without having to open it up
Luke e Savage - Reply Share
Where can i buy the lamp?
Keshawn Buckner - Reply Share
Merci pour ce tuto! =) ça ma permis de nettoyer la lentille qui était pleine de poussière!
Jules Schminke - Reply Share
Past 24 Hours: 6
Past 7 Days: 16
Past 30 Days: 82
All Time: 4,979
