Up to 20% off select tools
DBPOWER T20 Fan Replacement
Views: 1.7K
View statistics:
Past 24 Hours:
3
Past 7 Days:
11
Past 30 Days:
62
All Time:
1,737
Comments: 7
5 comments on steps, 2 guide comments.
Go to guide comments
Completed: 7
7 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 20 minutes
Difficulty: Moderate
Tools
  • Spudger
    4.9
Introduction
Go to step 1 ↓
Taking out the fan is quick and easy. When removing the fan it is okay to use some force as it's not delicate.
    1. DBPOWER T20 Fan Replacement, DBPOWER T20 Disassembly: step 1, image 1 of 1
      • Flip the device and lay flat.
      Ask FixBot
    2. DBPOWER T20 Fan Replacement: step 2, image 1 of 1
      • Remove the four (9 mm) screws with a PH2 screwdriver.
      • Remove the two (7 mm) located with a PH2 screwdriver.
      Ask FixBot
    3. DBPOWER T20 Fan Replacement: step 3, image 1 of 3 DBPOWER T20 Fan Replacement: step 3, image 2 of 3 DBPOWER T20 Fan Replacement: step 3, image 3 of 3
      • Flip the device over and pry the top off with a plastic opening tool.
      Ask FixBot
    4. DBPOWER T20 Fan Replacement: step 4, image 1 of 1
      • Remove the ribbon cable connecting the motherboard to the button control board by gently pulling it from its connector.
      Ask FixBot
    5. DBPOWER T20 Fan Replacement: step 5, image 1 of 2 DBPOWER T20 Fan Replacement: step 5, image 2 of 2
      • Remove four (6 mm) screws connecting the motherboard using a J0 screwdriver.
      Ask FixBot
    6. DBPOWER T20 Fan Replacement: step 6, image 1 of 3 DBPOWER T20 Fan Replacement: step 6, image 2 of 3 DBPOWER T20 Fan Replacement: step 6, image 3 of 3
      • Remove the two cables connected to the motherboard: black power cable and the red/black fan cable.
      • the black cable requires more force to remove than the other cables.
      Ask FixBot
    7. DBPOWER T20 Fan Replacement: step 7, image 1 of 2 DBPOWER T20 Fan Replacement: step 7, image 2 of 2
      • Lift the black latch on the ZIF connector and remove the ribbon cable that attaches the digitizer to the motherboard.
      Ask FixBot
    8. DBPOWER T20 Fan Replacement: step 8, image 1 of 1
      • Raise motherboard by lifting sideways and then up to avoid the ports.
      Ask FixBot
    9. DBPOWER T20 Fan Replacement: step 9, image 1 of 2 DBPOWER T20 Fan Replacement: step 9, image 2 of 2
      • Remove wires attaching the piezoelectric speakers to the motherboard.
      Ask FixBot
    10. DBPOWER T20 Fan Replacement: step 10, image 1 of 2 DBPOWER T20 Fan Replacement: step 10, image 2 of 2
      • Remove the five screws securing the black plastic cover with a J0 screwdriver.
      • Lift up and out to remove.
      Ask FixBot
    1. DBPOWER T20 Fan Replacement, Fan: step 11, image 1 of 2 DBPOWER T20 Fan Replacement, Fan: step 11, image 2 of 2
      • Pull the fan up and out of the housing.
      • In this image the lamp and power input have been removed to increase visibility, you do not have to remove these to remove the fan.
      Ask FixBot
7 other people completed this guide.
Author
with
Sebastian Alvarez de Araya
277 Reputation
1 Guide authored
USF Tampa, Team S16-G2, Boczar Spring 2018 Member of USF Tampa, Team S16-G2, Boczar Spring 2018
USFT-BOCZAR-S18S16G2
5 Members
60 Guides authored
2 Guide Comments
Any idea of the specifications of the fan? 12v, 24v? I want to change it for another more quiet… but not sure about its voltage. It is 50x50x20mm right? Thanks!
Agustín Castiñeira Fernández - Reply Share
Hola! También querria sustituirlo por otro más silencioso. ¿Alguna idea de sus especificaciones?
Joan Abrines - Reply Share
Past 24 Hours: 3
Past 7 Days: 11
Past 30 Days: 62
All Time: 1,737
