DBPOWER RD-810 Power Supply Switch Replacement
  1. DBPOWER RD-810 Power Supply Switch Replacement, Top Cover: step 1, image 1 of 2 DBPOWER RD-810 Power Supply Switch Replacement, Top Cover: step 1, image 2 of 2
    • Make sure the projector is unplugged before starting
    • Place the projector upside down to access the screws on the bottom.
    • Remove the five 7mm long screws using a #3 Phillips screwdriver at least 2 inches long.
  2. DBPOWER RD-810 Power Supply Switch Replacement: step 2, image 1 of 1
    • Flip the projector over and then remove the cover by lifting it up.
  3. DBPOWER RD-810 Power Supply Switch Replacement, Motherboard and LED Bulb: step 3, image 1 of 3 DBPOWER RD-810 Power Supply Switch Replacement, Motherboard and LED Bulb: step 3, image 2 of 3 DBPOWER RD-810 Power Supply Switch Replacement, Motherboard and LED Bulb: step 3, image 3 of 3
    • Remove the three 6mm PH2 phillips head screws.
    • Disconnect the ribbon cable by flipping up the latch on the connector and then pull the ribbon out.
  4. DBPOWER RD-810 Power Supply Switch Replacement: step 4, image 1 of 3 DBPOWER RD-810 Power Supply Switch Replacement: step 4, image 2 of 3 DBPOWER RD-810 Power Supply Switch Replacement: step 4, image 3 of 3
    • Disconnect the three wire connectors. Grasp both sides of the connector and pull apart.
    • Keep the connector parallel to the mother board to avoid breaking the solder connection.
    • Lift the motherboard up and place it out of the way.
  5. DBPOWER RD-810 Power Supply Switch Replacement: step 5, image 1 of 3 DBPOWER RD-810 Power Supply Switch Replacement: step 5, image 2 of 3 DBPOWER RD-810 Power Supply Switch Replacement: step 5, image 3 of 3
    • Remove the five 7mm PH2 phillips head screws on the black plate and lift the plate out.
    • Lift the aluminum heat sink up to remove it from the projector.
    • The motherboard is already removed in this step.
  6. DBPOWER RD-810 Power Supply Switch Replacement, Power Supply Circuit: step 6, image 1 of 3 DBPOWER RD-810 Power Supply Switch Replacement, Power Supply Circuit: step 6, image 2 of 3 DBPOWER RD-810 Power Supply Switch Replacement, Power Supply Circuit: step 6, image 3 of 3
    • Remove the two 9mm PH2 phillips head screws.
    • Lift the mirror behind the power supply circuit out to gain access to the circuit board.
  7. DBPOWER RD-810 Power Supply Switch Replacement: step 7, image 1 of 2 DBPOWER RD-810 Power Supply Switch Replacement: step 7, image 2 of 2
    • Lift the power supply circuit board out of the projector.
    • Disconnect the cable connector by pulling the two sides of the connector apart.
    • Keep the connector parallel to the circuit board to avoid breaking the solder connection.
  8. DBPOWER RD-810 Power Supply Switch Replacement, Power Supply Switch: step 8, image 1 of 3 DBPOWER RD-810 Power Supply Switch Replacement, Power Supply Switch: step 8, image 2 of 3 DBPOWER RD-810 Power Supply Switch Replacement, Power Supply Switch: step 8, image 3 of 3
    • Using the small plastic splunger, press in on the two latches on the sides of the power supply switch, then push it out of the case.
John Russell
941 Reputation
9 Guides authored
USF Tampa, Team S5-G3, Eyestone Spring 2018 Member of USF Tampa, Team S5-G3, Eyestone Spring 2018
USFT-EYESTONE-S18S5G3
3 Members
9 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 13
Past 30 Days: 59
All Time: 408
